Carbi Headlamp with remote phosphor
Hi Aswang,
my name is Pedro and I am the co-founder of Carbi. Thank you for posting our project in the forum.
I would like to clarify some of the questions from you and other members.
BUDGET: As you have guessed, even the price is not in the website yet, Carbi will not be a budget headlamp. We are working to reduce the cost, but as a startup and with a limited production quantity it will not be so cheap. Other reasons are that we are using only high quality components such as Panasonic cells, microprocessor with bluetooth, temperature sensor, battery monitor, aluminium case, sealing components, waterproof connectors, etc. Our aim is to create a really reliable and versatile product.
MODES: The modes are freely programmable with the App. The spacing in the specs is only intended for reference. I have added a note in the website to make it more evident.
SPOT BEAM: We use a White Cree XP-G3 (5700 K) and a Carclo lens. I am not sure what do you mean when you say it looks "ugly green". Any suggestion will be very welcome to improve this aspect.
COLORS: The lamp will be available (at least) in 3 colors: Cloud grey / Shadow grey / Golden yellow
REMOTE PHOSPHORS: It has been used before but only for low intensity headlamps and with standard phosphors. Carbi uses custom remote phosphors (will be available in at least 2 CCT) and the most challenging part of the design was how to integrate the spherical surfaces keeping the case compact and lighting the complete field of view of the user.
WEIGHT: 255g is the weight for a complete system (73g lamp with aluminum case + 128g battery including 18650 battery cells + 54g headband). We will also offer a lighter battery with 18500 cells.
BATTERY CELLS: Every user have different requirements, so in the model shown in the website the priority was to make ultra compact and lightweight. We will soon offer 3 battery models: Sport (2x18500, sealed, not LED indicators), Adventure (2x18650, sealed, LED indicators) and Explorer (aluminium case, 2x18650, replaceable cells, LED indicators).
WATERPROOF CONNECTORS: We are testing different waterproof connectors to ensure their durability at extreme temperature conditions.
TEAM: The "two guys" in the homepage are me and my colleague (co-founders), but we have worked with a Design Studio in Barcelona, Electronic Developer from Colorado, Programmer, ... So, yes, it is a big team for a startup!
You can answer here or write me an email at pedro[a]carbi.com for comments, questions or suggestions. You can also subscribe for further updates.
Can anyone smarter than me say whether this blue XPG3 and remote phosphor set up is really more efficient than a more traditional method such as LED+ floody optic or even a simple shallow OP reflector?
5700k is too cool for me for a headlamp, no mention of CRI.
Agree that mode spacing isn’t perfect, and low of 45lumens is too high.
I like the remote battery pack, it’s a shame more headlamps don’t offer this.
Edit to add: IP68 to 20m is impressive, I’d be curious how they prevent the water pressure activating the button…
Better performance compared to what? Everyone use aluminum! :smiley:
If you want truly high performance and better cooling you need to use copper. But its more expensive.
We are talking about the tint of the LED that you can find in the datasheet, tints in the green gamut are ugly. While others in the pink and red gamut are pleasant and more beautiful. Also CRI index is crucial for important work, for example an electrician selecting cables by color.
Some Remote Phosphor Advantages:
  • efficiency is improved by 20%, you can read in this article from Cree,
  • lower operating temperature,
  • longer LED and lamp lifespans,
  • better color stability in terms of color temperature and rendering index,
  • uniform light-emitting surface over a larger area,
  • allowed a customized lighting field (horizontally and vertically), to cover the complete field of view,
  • color output customization using a single type of LED.
Thanks a lot for your questions and kind suggestions.
WATERPROOF: The lamp is not designed for diving. IP68 is tested in static conditions and the 20 meters are just the pressure that it can withstand before water leakage during 1 hour. Minimum IP68 rating is 1 meter and it is up to the manufacturer to claim a higher number.
ALUMINUM BOARDS: For many users not experts in the matter it is important to provide the technical details. We are aware that Aluminum is not an innovation.
MODE SPACING: It is freely programmable, the steps in the table are only for reference.
Each LED board is independently connected to the control board, so it is possible to interchange or upgrade them. For FLOOD it is only needed to interchange the remote phosphors. So we plan to offer different options. It would be possible to choose between warm and cold light, but will you also interested in a mix, let's say cool spot and warm flood light?
Please consider sending a pre-release model of “CARBI” to one of reviewers on BLF!
Looks promising.
Hi Pedro, thanks for posting and answering questions here in BLF. I’m sure a lot of people including me will be keeping an eye on your Carbi headlamp since it’s quite unique. I’m particularly interested on how it would perform while caving. The remote phosphor is also interesting and quite unique for a headlamp.
Good to hear mode spacing is programmable since it was my major gripe. Just to clarify, “Ugly green” is tint snob speak and most people here in BLF know what I mean. I’m sure xpg3 5700K or any tint bin will satisfy most costumers. The higher lumen ratings should also help it sell more. But you should know that there are a few people (including me) who are very very picky with led tint. Especially for more expensive lights. You can blame Nichia for that. Almost all of the commercially available lights come with the (relatively) greenish tint and low CRI and we tend to replace them. But, good to know that this can be done with Carbi.
Do stick around. I’m sure you’ll get a lot of good insights from people here. And I agree with Boro that if you send samples for testing and review, consider sending some to BLF gurus. I’m sure they won’t mind testing your light.
G3s of any sort should never ever ever be used in a reflector. They have nasty angular tint-shift and will always result in a urine-yellow corona around a neutral(ish) hotspot with angry-blue spill everywhere else.
Behind a TIR lens should be okay, as long as it’s well-mixed (eg, wider-angle flood with pebbled front).
And quantity-over-quality to me just screams “cheap!”.
Best to just look into the LH351D or ’B for better quality light.
Indeed, and i’m quite sure anyone will be more satisfied with pleasant high CRI neutral CCT light without a green hue.
But perhaps most customers just don’t know this is very well possible nowadays, and just accept that LEDs are cold blueish white with lousy color rendition.
And an overall satisfactory experience when using the light.
True to an extent. But I know people who still prefer bluish, greenish low cri cold white despite me showing them the difference. They find neutral white, even my gorgeous nichia builds, too yellow.
Anyone with normal eyes can notice the better tint and CRI. THe difference is they will just call it high quality light without understanding the science behind it.
Thanks Boro, we will consider to send a sample for review. We have a few of our prototypes in Ireland, Spain and Taiwan. Where would have to be sent for review?
Thanks Aswang, Carbi was originally conceived as a Caving lamp trying to emulate the carbide headlamps light, but after we build the prototypes we found the flood light really interesting for many other activities where you need see around you. You can take a look to this video comparing Carbi with Scurion.
Thanks a lot for the feedback. We selected the XP-G3 from a efficiency point of view, but we have also noticed with our prototype about that urine-yellow corona. I am ordering right now a few new LED boards with LH351D for testing.
[quote=Pedro Albaladejo]
I would contact on BLF for one of our thorough reviewers.
We have a solid number of outstanding members/reviewers .
Contact the member and good luck.
Go to forums and look under LED headlamps.
ciao
Hi, just a quick update. We have finally decided to offer two ligth versions: cool light (5700K CCT and 80+ CRI) for people interested in lumens performance) and natural light (4000K CCT and 90+ CRI). You can see the specifications in our website, updated just a few days ago. We will use Cree for both versions, and as you can see in the datasheet, the CRI and CCT truly depends on the "Order Codes". For our first prototypes we (ugly green pictures) we requested samples with the highest lumens and therefore low CRI. We would love to have feedback from you, since we plan to start promoting the project again in the coming weeks. For those interested we will start a giveaway offer soon, we will inform in our newsletter after it is available. Thanks.
For your spot beam emitter, I would highly recommend avoiding the XP-G3 all together. Almost anything else will provide a better angular color consistency and better spot intensity. Also, for the spot beam, consider the units of cd/W rather than lm/W. This will undoubtedly shuffle the ranking of efficient emitters.
Here is a great review by a member here showing the weaknesses of the G3 in a narrow spot optic.
If you are still looking for a reviewer, I recommend Maukka hands down. We all look forward to his amazing color tests…
Also, I notice you now say you use UV emitters for the remote phosphors. It was previously mentioned they were Royal blue. Can you confirm and clarify this?
Also, what is the CRI rating of the remote phosphors setup?
WHITE XP-G3
We will check again with the hardware engineer about the white LEDs selection.
ROYAL BLUE
For the remote phosphor setup we use Royal Blue LEDs. The technical explanation at the end of the website mentions 'ultraviolet' for simplification; we will consider to review it to avoid any misunderstanding.
REMOTE PHOSPHORS SETUP
We have tested using domes from Chromalit and also from a local supplier here in Taiwan (I am Spanish but living in Taiwan). For our previous prototypes we used domes from the Taiwanese supplier, made of silicone and manufactured in a similar process to contact lens. And for the last prototypes we have used reworked domes from Chromalit, made of PC in a much basic manufacturing process. The results from the silicone domes were much better. Regarding the CRI we do not have the testing equipment in house and we are relying on the data reported by our suppliers. Both are reporting values between 80 to 90 depending on the color temperature of the dome.
REVIEWER
We have a few samples, so we could send one to Maukka. They are just prototypes but for a first review could be ok. The problem we may have is with the batteries shipping. For production we will use our supplier shipping license for lithium batteries, but for prototypes we can not ship them by flight. Where is Maukka located? We are a quite international team so we have batteries in US, Spain, Ireland and Taiwan.
I think maukka lives in Finland.
Sending the prototype to him would be nice in that he will make detailed measurement regarding the quality of the light.
Definitely want to see him review this torch.
