Assuming you are in smooth ramping mode, you can set the ramp floor minimum and maximum.
With light turned On, click 4 times fast. At the prompts (fluttering light) click 1 time it will respond and then then flutter a second time. This second flutter is where it sets the ramp max. Default is 21 clicks. If you click 1 time ramp max will be Turbo, so don’t do that, click 21 times.
Anduril is a little too easy to get into the menu settings, Imho.
You can also set the ramp min and max in stepped ramping. It has seperate settings. Same procedure except you make sure your in stepped ramping mode. It has a 3rd flutter which is the number of steps you want. Default is 7.
This also allows for two different momentary moon modes when the light is locked out. Hold gives you the floor for the current ramp and click, hold gives you the floor for the other ramp. Pretty cool, and one of the more obscure features.
One of mine no longer stops at the top of the ramp before turbo, meaning it no longer takes a double click to reach turbo. Did I accidentally re-configure it that way, or is it a quirk?
This is for the FW3A. All three originally required a double click to turbo, and now one of them doesn’t. It just ramps to turbo without a double click.
So I just got an 18350 tube from Illumn for my first production run FW3A, and can’t get the light to work with the short tube, I’ve taken it completely apart and cleaned everything before reassembling to no avail.
Wondering if anyone else has seen this and maybe an easy fix like lapping the inner tube a bit shorter or adding a small spacer in the threads to fix length issues?
Not that I can tell at least, I only have unprotected 18350 (the black keeppower high drain ones), the light does the ‘I’m connected’ quick flash when the head is screwed on about half way, but once tightened there is no response from the switch.
Make sure to loosen the head, then tighten the tail firmly, then tighten the head.
If still no switch contact, the battery might be a bit too long. Does it have a button top? Does it look like the button is being smashed in?
I don’t know what battery length they recommend, but you might try measuring your cell to see if it’s too long. I’m guessing someone knows the recommended 18350 length. You might try a 16340 cell if you have one.
Maybe others have tried that cell and can comment if it works or not.
