*BLF LT1 Lantern Project) (updated Nov,17,2020)
Thanks. Looks like I got it back in manual tint again now.
Yes. The button LED brightness is set as a side effect of the main LED brightness. When the lantern is awake but the main LEDs are off, the button LED turns off. When the main LEDs are on at about 0% to 40% brightness, the button LED turns on at a low level. And when the main LEDs are on at a higher brightness, the button LED turns on at a high level.
So if candle mode’s flicker pattern crosses either of those thresholds, the button LED flickers too.
I do like that side-effect :+1: :sunglasses:
Mines gonna be in customs the full 30 days on Tuesday. I’ve been waiting for what feels like forever.
I ordered mine on Jan1 and wasnt even going to check on shipping for a few weeks.
I was really surprised when it arrived on the 17th.
That is the fastest Ive had anything arrive from China.
The whole customs thing is pretty random. Mine spent about 9 days there, but recently cleared, it should be here in a few more days.
Just received my second order and Sofirn is still shipping with the batch 1 manual :frowning:
228 Oring - Imgur: The magic of the Internet
137 Oring - Imgur: The magic of the Internet
  1. fits a lot better than 228 with some positive retention, cannot come off that easily but Id want it tighter. I am thinking of trying 135 Next.
And just where did you source those?
These are standard O-ring sizes, I purchased them on amazon or ebay which ever is cheapest.
I just ordered #135 to see if that the winning one for the top
Here is a good list of them for sizes…etc, AS568 O-Ring Size Chart | Standard USA O-Ring Sizes
I didn’t know or think that there would be standard numbers for o-rings. That does make a lot of sense. Thanks for the reply and links.
Their are many different styles of O-rings for different applications.
Some even have flat side that are called Quad I think.
Apologies if this has been posted before. I searched on "LT1 shade" & didn't see anything that matched this.
A set of four silicone dog bowls were same price from Amazon as two or even one. That gave me some test subjects, the first being this green one. I'm satisfied with it, so I'll be duplicating this on a preferred yellow one.
I want to be able to use the bail along with the shade to hang the shaded light. I measured across the bail at the top of the head & came up with 50mm. Drew a line centered on the bowl, and pushed a heated nail into the silicone at the ends of the line. This should keep the cut from growing. This shows the cut ending at the holes.
Fits & works fine. I'll duplicate this on the preferred yellow bowl.
My light is factory stock. The bowl rests on the raised center of the head where the bolt enters. There's 5mm clearance around most of the remainder of the head for breathing room, and even more where the cutouts are for the folded bail. Does that allow enough space for air circulation to prevent the head from overheating?
slmjim
Great idea for the shade bowls! i had cut a round opening to fit over the lantern head, but your slot method seems to be much sturdier for keeping it in place. :+1:
Nice shade, slmjim! :+1:
I cut a 6 cm hole in my yellow ‘dog bowl’ like Den did.
It slides on from the top and rests snugly just above the groove for the orange o-ring. BTW, I moved the orange o-ring to the groove just above the switch.
My shade is 6 cm tall, and it completely shields the whole lens even when the LT1 is hung at eye level.
I’ve been running the LT1 on the lowest candle mode for several hours each evening since it arrived four weeks ago, and the cells are at 3.5 V today. I’m charging it for the first time right now. :partying_face:
Received the two lanterns w/batteries I ordered at the end of December. The cardboard boxes were soaking wet and there were droplets on the lanterns. Did the package fall off the boat? :slight_smile:
Batteries in lantern 1 were around 3.9v. When I charged them in my Xtar VC4 one battery took 90 mins longer to fully charge and only added 636mAh (vs 791, 799, 713 for the others). The resting voltage afterwards for that one battery was 4.15v vs. 4.17 & 4.18 for the others.
In lantern 2 one battery was 3.85v while the others were 3.98v. Charging in VC4 added 1116, 759, 779, 776mAh. Resting voltages were 4.18 & 4.19v.
Have anyone who ordered off of Amazon near the end of November received their lantern yet?
Order was placed on Nov 25th, shipped a couple days afterwards, and I received a tracking number that hasn’t updated since it was shipped.
The order on Amazon says expected to be delivered by Jan 28th so I’ve got a few days before that estimate lapses, I just wanted to know if there’s anyone else with a long wait time as well, still waiting for their lantern.
I have. I ordered on Amazon on Nov 26th, and had it in hand before Christmas (Dec 23rd). That was shipping to the Seattle area. My tracking number didn’t show any updates until Dec 16th, although Amazon still tells me that it’s “arriving before January 30th”.
If I were in your position, I would PM Sofirn and see if they can help you out.
I ordered one thru Amazon on Dec 9 and received it 12-27.
Do not depend on the Amazon tracking for shipments from China. Try searching on 17track.net Even though I have had mine for about 2 weeks the Amazon tracking only shows it has been shipped, whereas the 17track shows the path it took and is marked delivered “2019-12-27 12:01”
Ordered Nov 19, received Dec 23. Agree with track17, the only way to go until the package gets in USPS hands.
