I am not a big fan of short lasting turbo levels. :laughing:
Basically the host can handle ~1500 lumens from an XHP50.2 continuously, so the high of this driver with ~1400lm is good, and the turbo is ~2000lm and can be activated separately. This one also have good mode spacing.
Moreover, 6V output buck drivers cannot hold constant current through the whole 2S battery capacity range in high levels, considering the 6V emitter Vf, the battery voltage, and the driver maximum output voltage ( which is ~Vin-0.3V in the best case ).
[quote=Lacerta]
Finally I started to rebuild the host. And also I made some further tests with better wiring.
The first 3 levels are good. Input values are showing constant output values which are corresponding to the specs. With the 3V XH50.2 50mA, 150mA, and 750mA. For 6V led 100mA, 300mA and 1500mA is specified.
But at high and turbo level… The driver seems to get mad. :person_facepalming:
The input current should be around ~1.6 and 2.4A.
But it’s 3.4A at high and 4.5A at turbo! And the inductor is whining like hell. Seems that the regulation is not working properly at higher levels at the increased Vin/Vout ratio. :cry:
I wonder whether the replacement of the inductor would help this? Currently a 4.7uH is installed.
Finally I started to rebuild the host. And also I made some further tests with better wiring.The first 3 levels are good. Input values are showing constant output values which are corresponding to the specs. With the 3V XH50.2 50mA, 150mA, and 750mA. For 6V led 100mA, 300mA and 1500mA is specified.
But at high and turbo level... The driver seems to get mad. :FACEPALM:
The input current should be around ~1.6 and 2.4A.But it's 3.4A at high and 4.5A at turbo! And the inductor is whining like hell. Seems that the regulation is not working properly at higher levels at the increased Vin/Vout ratio. :((
Hello Lacerta,
This thread's been sleeping for a couple months, it would be helpful if you could recap a little bit better what you are trying to diagnose. This is, are you having trouble powering up an 1S emitter (confirmed) with a ∅22 mm Manta Ray buck driver?
You say the driver is pulling (input) ≈3.4 and ≈4.5 A in high and turbo? Could you measure the output figures? That would help to diagnose what is going on. That seems pretty weird but if the thing is really doing its job efficiently the output should be about twice the preceeding input figures (I presume it is being fed with 2S cells).
The inductor may require a swap for better driving 1S/3V emitters (higher inductance). I'm no expert in these matters so wait for some proper connoisseur to chime in.
Hi Barkuti,
Yes, that’s the exact driver.
I did not check the output values since the led base was soldered to the driver. But the led was very bright and dissipated very much heat very quickly.
Another interesting fact. Before this testing, I made another one. The led was also soldered to the driver, and the supply was delivered to the driver through crocodile clips. But the first case the clamping was less firm.
At that case, the input current was ~1.7A in the 4th level and there was no inductor buzz. It is a little high comparing to the expected 1.6A, but still OK. In turbo, the input current was ~3.2A and the inductor had audible whistling.
Previously, I experienced quite similar results when the led was clamped to the driver with crocodile clamps.
For me, it means that any factor which limits the current like wiring / contact resistance helps to eliminate / decrease the inrush.
It seems that the inductor core is saturating and that’s why the PWM controller cannot stabilize the output current. Since the duty cycle is lower than with 6V leds, the peak currents ( caused by higher voltage difference ) should be too high.
And that’s raise a dilemma!
To avoid saturation, a lower inductance needed ( assuming the same inductor size - it’s 1040 actually ). But it also furtherly increases peak currents. To lower peak currents, higher inductance is required. But higher inductance has lower saturation currents.
Of course, using a bigger size inductor is an option, and there’s place to install. The problem is here that there’s a huge selection of cheap 1040s to play with, but not from bigger sizes.
Wellp, as I said before I can't assess the optimization needs for that driver to operate nicely with slightly larger input to output voltage difference, although I can read and pinpoint some interesting tutorial/article like How to Choose the Right Inductor for DC-DC Buck Applications @ Passive Components Blog.
I bought some Murata FDA1254-H-4R7M (half an inch square, 4.7 µH, rated current Isat/Itemp: 11.2/10.2 A) inductors for a crazy mod project more than a year ago, do you think these would do the job any better?
No, I did not expect You to tell the Highest Wisdom.
Just talking about modding.
The working theoretics are clear for me, but the calculations are not easy since the major vast of required data is not available.
Though, it is clear that increasing the voltage difference between Vin and Vout reguires higher inductance value for the same ripple.
In the meantime I got remembered that I have some spare inductors in my loot trunk.
And I’ve found some 4.7uH inductors and also some 10uHs. different sizes, different qualities. Some of them are Coilcrafts.
I removed the original inductor and will test the other ones.
Thanks for the tips!
Looking more closely the stock inductor looks about ½" × ½" (more or less like the Murata I mentioned above) so, if its inductance is 4.7 µH, its current specs should be high enough. But of course, very possible it is that whoever is making these drivers may not be purchasing top spec inductors. Just a little bit more inductance should be fine.
You might try the xal7070 series coilcraft inductors. I have used a few and never heard a whine.
Has a low DCR so you should gain a little current without the whine.
The New XGL series looks interesting.
Looking more closely the stock inductor looks about ½” × ½” (more or less like the Murata I mentioned above) so, if its inductance is 4.7 µH, its current specs should be high enough. But of course, very possible it is that whoever is making these drivers may not be purchasing top spec inductors. Just a little bit more inductance should be fine.
Actually, it’s a 1040 size inductor. On my driver it’s not covered by glue and the 4u7 mark is clearly readable.
The size is not a big constraint, bigger inductors can be easily installed.
XAL7070 Series High Current Shielded Power Inductors | Molded Inductor | Coilcraft
I’ve found in 4.7uH some MSS1048 Coilcrafts, some SER1360s and a noname 1080 one. Also have some 10uH SER1360.
I will test whether the inductace value, or the current handling capability is the bottleneck factor.
Wellp Lacerta, according to what you are saying the stock 10 × 10 × 4 mm inductor in the Manta Ray driver is likely doing its best already, or very close. I mean, were they had chosen a lower specified inductor the driver would have malfunctioned.
The way metal alloy inductors work, their inductance diminishes as they approach their current limits. This basically means a proper quality, higher current rating bigger inductor quite likely will work right even if the Vin to Vout delta is somewhat bigger.
Now that I think of it, the FDA1254s I have lying around will find home in some of these drivers sometime, hope I can raise the current output a nice bit with them. ;-)
Considering the 1040 data sheets ( on Aliexpress ), 4.7uH coil saturates at 12A, and can handle 9A RMS. Now we have 4.8A RMS. We should have.
Of course, maybe these should be interpreted as chinese ampers. :smiling_imp:
I will try other inductances and will feedback about the results.
The FDA1254-H-4R7M (12.6 × 12.5 × 5.4 mm including terminals, 4.7 µH, rated current Isat/Itemp: 11.2/10.2 A) I spoke about earlier is noticeably bigger and does not reach your above figures. So something's wrong, and I guess Murata is not.
Yes, in same size Coilcraft inductors are not such good either.
Should be chinese ampers, as they invented chinese lumens too.
No success. Mission Failed.
I’ve tried several inductors, all of them had higher current handling capacity than the original 1040/4.7uH.
Some had same inductance, some had higher ( up to 10uH ).
Still no stabilzaton on high and turbo, and all the coils were saturating.
It means that the saturation is not the rootcause, only the consequence. Consequence of the converter runs with false current sensing or regulation.
I don’t know the reason.
I should look for another solution ( driver ).
Hey guys;
Since we are here in a boost driver modding discussion…I’d like to get some help in modding this xhp35 2.3A driver from convoy;
Can anyone tell from the pictures of the board, or by experience if it is possible to make it Single , turbo 100% Mode only? The led is just perfect for my project
except for that reason
thanks alot
Hey Fabio, could I ask, do you want to use it with an XHP35? And with single battery supply?
yep exactly, do you think it is possible??
It's certainly possible; it's pretty simple. Just connect a piece of wire like this:
I posted more detailed information on this Convoy driver here: https://budgetlightforum.com/t/-/61809
It uses the MP3431 chip, and works really well.
I include schematic, board layout, and testing results. I invite anyone in this thread to check it out if you’re interested.
