I understand the spectral errors but misunderstood your previous post.
UT383 is the only cheap meter that you tested which doesn’t significantly overread the blue peak of cool low-CRI lights.
It loses at the far red. And the sensitivity peak is shifted. I don’t claim it’s great but to me it looks significantly better than anything up to several times its price.
As an owner of so many Virence modded Tiara Pros with the same emitter, even the 200+ lumen mode is VERY bright. It’s much brighter than I imagine at that lumen level and I’m a fan of lumen monsters. You can see everything very clearly. Probably the ultra HI cri helps. Most of the time I use the sub 10 lumen modes as that is already real bright at night when my eyes are adjusted and even at that lumen level you can make out all the details and colors. For anyone who is hesitating to buy this because of the low lumen rating, trust me you will not be disappointed and you will be using it everyday, likely on the very low levels.
I’m interested in this group buy, just checking that the buy occurs after 200 orders? Only asking because there are currently 100 rows in the google doc.
If we can hit 200pcs then we can request Skilhunt to make us custom mode/output (no timed step down). Otherwise, we will order any quantity but, with normal mode/output like OEM.
Thank you for answering; I ended up playing with my ZL to see how bright 200-ish lumens is and yeah it does seem pretty bright to be honest. I did just buy a “normal” Skilhunt but if this reaches 200+ units for the custom mode/UI I’ll join in.
This would make it better. The ability to just hold the button from off to get to the desired brightness is my most used feature in Anduril or Narsil. I always end up locking the H04 or my rofis r1 and r2 because of this. Make lockout 4 clicks or something if it’s possible.
Flashaholics only knows how to appreciate 5700K tint. He is not a HI CRI and tint fan and does not have equipment to test light quality. What is special about this headlamp is the ultra hi cri E21A emitters. Maukka already tested each one and his test reports are on Virence.com I also tested the same emitters in my Virence.com modded Tiaras and my results are posted in this thread. The performance of the quad E21A in the H04RC should perform the same since it will use the same beaded optic.
