Interested
Very interested
Replied. [quote=Kit Latura] Interested [/quote]
Ordered
Thank you for your continued support! :BEER: :THUMBS-UP:
Mine has arrived without manual. Any idea where to get it?
What is supposed to be inside the package?
Driver works at 4A (max) and I can’t see flickering PWM.
It has temperature protection like new Convoy Drivers.
Great light! This seems to be the “natural” evolution of their VG10!
Flashlight alone according to BG site.
From what i understand:
Operation:
Configuration mode:
- 5x quick half press when light is in ON state.
- Flashlight will flash 1x > 2x > 3x > 4x > 5x time sequence. Number of flashes correspond to the group number.
- Turn OFF the light to select your preferred group. ( example: to select group #2, turn OFF light when XT35 flashes twice.
5 groups:
- 2000lm
- 2000lm - 10lm (default)
- 2000lm - 400lm
- 2000lm - 1200lm -10lm
- 2000lm - 12000lm - 400lm -10lm
Double-click to enter Strobe in any modes.
Image via AMUTORCH buyer
Not working, I can’t change between different group modes. And can’t enter to strobe.
My XT35 is not like your photo. It hasn’t written XT35 anywhere, only B35 on head
freeme:Flashlight alone according to BG site.
Kit Latura:Mine has arrived without manual. Any idea where to get it? What is supposed to be inside the package?
Operation:
Configuration mode:
- 5x quick half press and release (when light is in ON state).
5 groups:
- 2000lm
- 2000lm - 400lm
Not working, I can’t change between different group modes. And can’t enter to strobe. My XT35 is not like your photo. It hasn’t written XT35 anywhere, only B35 on head
Does it goes into configuration mode >>> 5x quick half press and release (when light is in ON state)?
Kit Latura:Not working, I can’t change between different group modes. And can’t enter to strobe. My XT35 is not like your photo. It hasn’t written XT35 anywhere, only B35 on head
No
Strange. Are you able to switch between different light level? Do you recognize any of the stated grouping?
This should be the updated one.
5 groups:
- 2000lm
- 400lm-1200lm-2000lm
- 100lm-400lm-1200lm-2000lm
- 10lm-400lm-1200lm-2000lm
- 10lm-100lm-400lm-1200lm-2000lm
freeme:Does it goes into configuration mode >>> 5x quick half press and release (when light is in ON state)?
No
quote=Kit Latura]
No
Maybe 2000 - 400. Not 2000-10 of default mode. I’m sure about this. Strobe mode still inaccessible
My switch is forward clicky. It’s right?
Do you have a soldering iron? I just realized that there are two type of driver for this light on AMUTORCH TaoBao.
The list that i have posted is for Daily Mode firmware. Very high chance that your version is Tactical Mode version, which requires you to manually select the group by bridging the pads shown in pic. Are you able to check yours?
freeme:Strange. Are you able to switch between different light level? *Do you recognize any of the stated grouping?*
quote=Kit Latura] [quote=freeme]
[/quote]
NoMaybe 2000 - 400. Not 2000-10 of default mode. I’m sure about this. Strobe mode is inaccessible
If remove the bridge there’s only the high mode.
With the pads bridged, it have group mode of 2000 and 400 lumens, again.
there is some solder in the red area. Can it have something to do with it?
Seems correct, no bridge equal to group #1, single mode at 2000lm.
If remove the bridge there’s only the high mode. With the pads bridged, it have group mode of 2000 and 400 lumens, again. !Telegram: Join Group Chat! there is some solder in the red area. Can it have something to do with it?
You tried soldering the grouping that you want? Or you mean you can only get 2000-400, despite bridging a different pad?
