Some first designs of the driver
as discussed one with a red channel the other with a Turbo mode
Diameter 25mm with USB-port has resistors to charge directly on a USB-C wall adapter
TP5100 up to 2A fast charging with 5-18V input (not QC or PD, but good for direct connection to 12V solar panels)
Thanks for the comments :+1:
As we to get power outages quite often, the LT1 has lit many nights here, and i still use the first production one i received as my main night table light, running on moon or candle mode every night.
This new thread is dedicated to the LT1M Mini, which is the answer to the many wanting a pocket-sized, back-pack sized portable version for camping trips, and even be the little brother/sister to your full size LT1 Lantern.
I will be doing a video soon on some custom built super micro lanterns, even one that can fit in your wallet, emit the same light or more of a candle 360 degrees , & run for 40+ hours.
Yes, sort of. The entire lantern in only 4.5 millimeters thick, uses a very unique remote-phosphor LED (very hard to find) that emits Warm white nearly 360-degrees like an incandescent bulb, can run from a single CR2032 Lithium coin-cell for 12+ hours brighter than a candle, (tested) then run for an additional 30+ hours dimming down to a moon light, but this wallet lantern has two slots for two CR2032 cells in parallel to double those run times, (or save one as a reserve back-up cell after the first is spent.) I have one in my wallet now. the video will reveal this “24+ hour wallet candle” when i create that topic.
