** BLF LT1M-Mini Project - The little Lantern! **
775 posts / 0 new
LT1-Mini-Project
LT1-Mini-Project's picture
Last seen: 3 days 11 hours ago
- Welcome everyone!
> UPDATE,Feb,12,2020
- Ok all, here is the video explaining how i refined a lantern head for the LT1 Mini and still use the original IF25 LED up-firing configuration, with the original quad-TIR optic still used. I will get the drawing of how it was done completed soon, explaining its principle and how the Mini V1 prototype works. Here i have modified the LT1 Mini with the same LH351 2700K and 5000K 3535 LEDs as used in the full size LT1 lantern. As planned for the production version, it will have the same LT1-Andruil operating firmware as the fullsize LT1, some body design changes, side switch changes, base cap changes to add a removable magnet, (the magnet will help hold a wider accessory base plate for more stability) and add a 18650 sleeve so it can be used with a single 21700 or 18650 cell.
- Members asked for a more compact, backpacking-sized version of the LT1, and we have listened, & will create that Mini-version, like the Mini-GT was created, the LT1 will have a baby variant with nearly the same features. Big Smile
- Here is the new separate build topic for the new planned Sofirn BLF LT1M (LT1-Mini)
Barry & Sofirn sent a couple candidate hosts that i examined & tested as a platform for the LT1M , (an IF25 and SP33) I disassembled both lights, worked with them to see which one would be the best foundation for a mini LT1, and the IF25 was the clear winner. As the IF 25 already has USB-C charging, 21700 support, compact design, AND already has tint ramping with four 3535 LEDs, it is the perfect starting point for the Mini.
So i re-worked the IF25 with the same Samsung LH351 2700K and 5000K LEDs as the LT1 full size, then i spent countless hours of testing every type of shade and globe design, and finally came up with one that works perfectly to create a 360 degree very smooth, even, low-glare light using the IF25’s existing up-firing LED design as used for the flashlight. The LT1-Mini will be much easiwer & simpler to work to get into production than the LT1 was, as the host IF25 already has some good starting points. (the charging, the 21700 format we want, tint ramping etc.
All we need to work on is to get Toykeeper’s LT1 Andruil programmed to this driver, (if the driver needs alterations to accept Andrul maybe Lexel can have a look at that) possibly change the switch LEDs to match and work the same as the full size LT1, and maybe some changes to the LT1M body to ad knurling to match the full size LT1. I will be posting design drawings and photos of how i got the new shade to work so well with an up-firing design soon, and create a video of what went behind the LT1M to get it what i have now as a V1-Mini prototype.
While the high-mode run times may be a bit less than the full size LT1, the plan is to still focus on great run times as much as we an from a 21700 single cell, with the same high CRI 2700K to 5000K tint ramping, Toykeeper’s amazing Andruil-LT1 firmware operating system, a high degree of light transmittance angles, low-glare, USB-C charging, all the best features of the full size LT1 but in a more compact, pocketable, backpacking friendly mini-version.
- Below, is the completed, & tested LT1M-V1 Prototype, along side the full size LT1, and second photo shows how smooth and even the light transmittance is, which is very close to that of the full size LT1. Maximum lumens are average of 350 to 400 lumens output, with that beautiful adjustable High-CRI tints of the sofirn BLF LT1. Thumbs Up
We will begin an interest list as we did with the full size LT1 once we get the new office-set up for the build team, so stay tuned for updates, and a video soon of the birth of the LT1-Mini. Big Smile
BLF LT1-Mini Lantern Project
Edited by: LT1-Mini-Project on 02/12/2020 - 13:52
LT1-Mini-Project
Interest list as of 10/25/2020 1:15PM PST. Last post added to list was 770.
Interest List By Name
Interest List By Number
Post# / Added / User Name
1 / 02/05/2020 / DBSAR
7 / 02/04/2020 / goshdogit
10 / 02/04/2020 / lotrbfme
19 / 02/04/2020 / Greener
20 / 02/04/2020 / SIGShooter
22 / 02/04/2020 / AEDe
23 / 02/05/2020 / litenutz
24 / 02/05/2020 / DrDevil
25 / 02/05/2020 / agent80
26 / 02/05/2020 / taenzerwalze
27 / 02/05/2020 / leo l.
28 / 02/05/2020 / ger-slash
29 / 02/05/2020 / qandeel
30 / 02/05/2020 / chris.zerocool
31 / 02/05/2020 / Nicolicous
32 / 02/05/2020 / zelee
33 / 02/05/2020 / Nagonka
34 / 02/05/2020 / Marc E
35 / 02/05/2020 / raccoon city
36 / 02/05/2020 / MascaratumB
37 / 02/05/2020 / Dep668
38 / 02/05/2020 / Quillz
39 / 02/05/2020 / TMaxxJJ
40 / 02/05/2020 / rahdi
41 / 02/05/2020 / Muto
42 / 02/05/2020 / TexasToasted
45 / 02/05/2020 / Big_Sam
46 / 02/05/2020 / jacktheclipper
47 / 02/05/2020 / djozz
48 / 02/05/2020 / thisnameisvalid
50 / 02/05/2020 / specialk
51 / 02/05/2020 / bonC
52 / 02/05/2020 / mili111
53 / 02/05/2020 / ValuseekeR
54 / 02/05/2020 / ch1ir
55 / 02/05/2020 / mitsuki08
56 / 02/05/2020 / twodollarbill
57 / 02/05/2020 / Alphacentaury
58 / 02/05/2020 / P33
59 / 02/05/2020 / Moe_Suki
60 / 02/05/2020 / Kevin Z
61 / 02/05/2020 / Melez
62 / 02/05/2020 / gottawearshades
63 / 02/05/2020 / Bhevo47
64 / 02/05/2020 / BT100
65 / 02/05/2020 / netprince
66 / 02/05/2020 / fuzun
67 / 02/05/2020 / Ironhorse
68 / 02/05/2020 / Satan@103TFS
69 / 02/05/2020 / Dougdimadome
70 / 02/05/2020 / Th558
71 / 02/05/2020 / Grigio
72 / 02/05/2020 / atobe
73 / 02/05/2020 / northbeard
74 / 02/05/2020 / olivedrab
75 / 02/05/2020 / Chatika vas Paus
76 / 02/05/2020 / christoph
77 / 02/05/2020 / flightless22
78 / 02/05/2020 / man of light
79 / 02/05/2020 / wolfstyle
80 / 02/05/2020 / wolfstyle
81 / 02/05/2020 / jigsaw
82 / 02/05/2020 / Light Years
84 / 02/05/2020 / azhu
85 / 02/05/2020 / seriesone
87 / 02/05/2020 / BorisBar
88 / 02/05/2020 / noboneshotdog
89 / 02/05/2020 / SoCal5150
90 / 02/05/2020 / cm02WS6
91 / 02/05/2020 / LeftWing
92 / 02/05/2020 / Gunga
93 / 02/05/2020 / Perception
94 / 02/05/2020 / DarkShot
95 / 02/05/2020 / SlvrDragon50
96 / 02/05/2020 / raccoon city
97 / 02/05/2020 / quvantage
98 / 02/05/2020 / contactcr
99 / 02/05/2020 / nastynate
100 / 02/05/2020 / Calzoner
101 / 02/05/2020 / bikenber73
102 / 02/05/2020 / JermsMalibu
104 / 02/05/2020 / dealgrabber2002
109 / 02/05/2020 / FlashPilot
110 / 02/05/2020 / Spacegrass
111 / 02/05/2020 / nick91900
112 / 02/05/2020 / Sudsy
113 / 02/05/2020 / Sparks65
114 / 02/05/2020 / MNLegoBoy
115 / 02/05/2020 / Forever
116 / 02/05/2020 / aginthelaw
117 / 02/05/2020 / wapd2
118 / 02/05/2020 / belgarath
122 / 02/05/2020 / Aulic458155
125 / 02/05/2020 / Tubercle
127 / 02/05/2020 / OldSkol
128 / 02/05/2020 / korpzgrinda
129 / 02/05/2020 / That’ll Leave A Mark
130 / 02/05/2020 / Luminosity
131 / 02/05/2020 / lumiere
132 / 02/05/2020 / Stittville Ed
133 / 02/05/2020 / 2Ace
134 / 02/05/2020 / SoulCraves
135 / 02/05/2020 / JoeH12.81
136 / 02/05/2020 / rizky_p
138 / 02/05/2020 / CJ Avlis
139 / 02/05/2020 / Quillz
140 / 02/05/2020 / staticx57
141 / 02/05/2020 / middle age man
142 / 02/05/2020 / blueb8llz
144 / 02/05/2020 / California_Prepper
146 / 02/05/2020 / Chinaheart
147 / 02/05/2020 / D10ten
149 / 02/06/2020 / Xandre
150 / 02/06/2020 / cu42
151 / 02/06/2020 / lamppu
152 / 02/06/2020 / arisdes
153 / 02/06/2020 / Funzel67
154 / 02/06/2020 / YahFargo
155 / 02/06/2020 / carmantl
156 / 02/06/2020 / ShyOne
157 / 02/06/2020 / vkor
158 / 02/06/2020 / Slayer1
159 / 02/06/2020 / adirondackdestroyer
160 / 02/06/2020 / PoliceScannerMan
161 / 02/06/2020 / 1332332331
162 / 02/06/2020 / rockhound42
163 / 02/06/2020 / KevinZA1988
164 / 02/06/2020 / MonkeyLight
166 / 02/06/2020 / gungoat
167 / 02/06/2020 / obriencr
168 / 02/06/2020 / luisgcan
170 / 02/06/2020 / SKV89
173 / 02/06/2020 / Watermanchris
175 / 02/06/2020 / MrLumen
176 / 02/06/2020 / Cythras
177 / 02/06/2020 / EcuBebge
178 / 02/06/2020 / Nguyen
179 / 02/06/2020 / Hoosh
180 / 02/06/2020 / Klotski
181 / 02/06/2020 / mizjif
182 / 02/06/2020 / firstcipher
183 / 02/06/2020 / chinooker
184 / 02/06/2020 / Phlogiston
185 / 02/07/2020 / INFRNL
186 / 02/07/2020 / species8472
187 / 02/07/2020 / lightboks
188 / 02/07/2020 / light_man89
189 / 02/07/2020 / Nicolicous
190 / 02/07/2020 / LSX
191 / 02/07/2020 / olles
192 / 02/07/2020 / jmoots
193 / 02/07/2020 / derfyled
194 / 02/07/2020 / DunchBlaster
195 / 02/07/2020 / Nicko69
196 / 02/07/2020 / ossifrage
197 / 02/07/2020 / RollerBoySE
199 / 02/07/2020 / LDIBP
200 / 02/07/2020 / jdunlap27284
203 / 02/08/2020 / Lips
204 / 02/08/2020 / Toglud
205 / 02/08/2020 / 808Hi
206 / 02/08/2020 / Julez
207 / 02/08/2020 / TUNE4IT
208 / 02/08/2020 / Gr8Swammee
209 / 02/08/2020 / thijsco19
210 / 02/08/2020 / The Whispering Gallery
211 / 02/08/2020 / 4492011
213 / 02/08/2020 / Lemurian
214 / 02/08/2020 / CalDellinger
215 / 02/08/2020 / justanotherguy
216 / 02/09/2020 / gman7228
217 / 02/08/2020 / scintillator
218 / 02/08/2020 / goshdogit
220 / 02/08/2020 / Coscar
221 / 02/08/2020 / noetik
222 / 02/08/2020 / Phoneas
225 / 02/09/2020 / Kennyboy
226 / 02/09/2020 / marcus_z
227 / 02/09/2020 / russthetoolman
228 / 02/09/2020 / Misthailin
229 / 02/09/2020 / nsk1979
230 / 02/09/2020 / lamacik
231 / 02/09/2020 / f0xx
232 / 02/09/2020 / Geese
233 / 02/09/2020 / SwissFlashy
234 / 02/09/2020 / rom
235 / 02/09/2020 / JoeRodge
239 / 02/09/2020 / Mkduffer
240 / 02/09/2020 / patmurris
241 / 02/09/2020 / Geronimo
242 / 02/09/2020 / dekozn
244 / 02/09/2020 / hodor
245 / 02/09/2020 / Asian8640
246 / 02/09/2020 / mgracia85
247 / 02/09/2020 / JermsMalibu
251 / 02/10/2020 / d_t_a
252 / 02/10/2020 / quijibo
253 / 02/10/2020 / mattlward
254 / 02/10/2020 / akoposilester
255 / 02/11/2020 / delete
256 / 02/11/2020 / mlodyulek
257 / 02/11/2020 / Chinaheart
259 / 02/11/2020 / KgaBombadier
260 / 02/11/2020 / Yacob29
261 / 02/11/2020 / MCT
262 / 02/11/2020 / andyxxx
263 / 02/11/2020 / Angel Mart¡nez
265 / 02/11/2020 / shirnask
268 / 02/11/2020 / Boro
269 / 02/12/2020 / mpak87
270 / 02/12/2020 / Majoroverkill
271 / 02/12/2020 / Boaz
272 / 02/12/2020 / Day_Light
273 / 02/12/2020 / johnpc
274 / 02/12/2020 / mukenukem
275 / 02/12/2020 / mmxrico
276 / 02/12/2020 / Sparky.
278 / 02/12/2020 / alex64
280 / 02/12/2020 / vinte77
282 / 02/12/2020 / kemosabi
285 / 02/12/2020 / dick33
286 / 02/13/2020 / led_400
288 / 02/13/2020 / el_duderino
289 / 02/13/2020 / Caleb
292 / 02/13/2020 / Kombatt
293 / 02/13/2020 / atabalat
294 / 02/13/2020 / PBNinja
297 / 02/13/2020 / Marcello
299 / 02/13/2020 / Funtastic
302 / 02/13/2020 / soldsoulrockroll
303 / 02/14/2020 / Orodizi
304 / 02/14/2020 / Hell2Pay
306 / 02/14/2020 / Lazy-J
307 / 02/14/2020 / Silent_Star
308 / 02/14/2020 / atobe
310 / 02/15/2020 / aswang
311 / 02/15/2020 / mr_magoo
312 / 02/15/2020 / Mr.Beam
313 / 02/15/2020 / Kevin Z
314 / 02/15/2020 / Costom56
317 / 02/15/2020 / apt323
318 / 02/16/2020 / netgear68
319 / 02/16/2020 / Pugna
320 / 02/16/2020 / mortuus
321 / 02/16/2020 / macgyver88
323 / 02/17/2020 / JermsMalibu
325 / 02/17/2020 / ReallyInToCheese
326 / 02/17/2020 / Qwibbles
327 / 02/18/2020 / Gj
328 / 02/18/2020 / chrisddo
329 / 02/18/2020 / tra192
330 / 02/18/2020 / twodollarbill
331 / 02/18/2020 / Madtoffel
332 / 02/18/2020 / Sherbona
333 / 02/18/2020 / yasenf
334 / 02/18/2020 / Itsme
339 / 02/18/2020 / occulai
340 / 02/19/2020 / Ilumenati
341 / 02/19/2020 / CubicalBeaver
342 / 02/19/2020 / headburger
346 / 02/19/2020 / FBsLights
347 / 02/19/2020 / Krah
349 02/20/2020 Kozy
349 02/20/2020 Kozy
350 02/20/2020 species8472
351 02/20/2020 cujo255
352 02/20/2020 niktak11
353 02/20/2020 bobofire
354 02/20/2020 royalomaha
355 02/21/2020 xenotar80
356 02/21/2020 marknate24
357 02/21/2020 h5550
358 02/21/2020 DaveyC
359 02/21/2020 leroycp
360 02/21/2020 Dirt
360 02/21/2020 Dirt
361 02/21/2020 kazibole
362 02/21/2020 Backpacker Light
363 02/22/2020 paetzi
365 02/23/2020 Helios azimuth
366 02/24/2020 kleft
367 02/24/2020 NuggetMcNugget
368 02/24/2020 briprox
369 02/24/2020 DBSS
369 02/24/2020 DBSS
371 / 02/25/2020 / XXX-Man
372 / 02/27/2020 / rrushx
373 / 02/27/2020 / BillyBobJoe
374 / 02/28/2020 / rost333
375 / 02/29/2020 / Discharger
376 / 02/29/2020 / barbuto
377 / 02/29/2020 / takumi86
378 / 02/29/2020 / Ilumenati
379 / 02/29/2020 / obriencr
380 / 02/29/2020 / Myke
381 / 02/29/2020 / csabaki
382 / 03/01/2020 / BRAVO
383 / 03/01/2020 / Whyaskus
384 / 03/01/2020 / ulfm1
385 / 03/01/2020 / BrianCharles
387 / 03/01/2020 / syracuse
388 / 03/02/2020 / runplayewin
389 / 03/02/2020 / Coaster
390 / 03/02/2020 / Fubarge
391 / 03/02/2020 / legan710
392 / 03/02/2020 / fluke
393 / 03/02/2020 / kotobuki
394 / 03/03/2020 / jericho0o
395 / 03/03/2020 / etienne440
396 / 03/03/2020 / Ringmaster242
397 / 03/03/2020 / Tdh66
398 / 03/04/2020 / lantlight
399 / 03/04/2020 / man of light
400 / 03/04/2020 / man of light
401 / 03/04/2020 / Woody
402 / 03/04/2020 / greymage
403 / 03/04/2020 / Leelou
404 / 03/06/2020 / asdqqq
405 / 03/06/2020 / jkbam
406 / 03/06/2020 / vestureofblood
407 / 03/06/2020 / GreenCampfire
408 / 03/08/2020 / toxiccoccyx
409 / 03/08/2020 / deathless
410 / 03/08/2020 / JohnnyUtah
412 / 03/09/2020 / Tixx
413 / 03/10/2020 / toobadorz
414 / 03/11/2020 / treadhead71
415 / 03/11/2020 / Mr.Poppy
416 / 03/14/2020 / Danthemanz
417 / 03/14/2020 / jacktheclipper
418 / 03/14/2020 / steel_1024
419 / 03/15/2020 / ductue89
421 / 03/16/2020 / mustig
423 / 03/16/2020 / theoldbill
424 / 03/17/2020 / gotang
425 / 03/17/2020 / Asian8640
426 / 03/23/2020 / AgentWhiteBread
427 / 03/23/2020 / Anthon
428 / 03/23/2020 / gangstead
429 / 03/23/2020 / Sunnysunsun
431 / 03/23/2020 / nightshark
433 / 03/24/2020 / bobkido
436 / 03/27/2020 / slowtechstef
437 / 03/29/2020 / creynolds
438 / 03/29/2020 / KnotSoMuch
440 / 03/29/2020 / Itsme
441 / 03/29/2020 / write2dgray
442 / 03/29/2020 / iwandutchy
443 / 03/30/2020 / Chappy
444 / 03/30/2020 / JorisFRST
447 / 03/30/2020 / Julez
448 / 03/31/2020 / Wave180
450 / 04/02/2020 / Nismo
451 / 04/02/2020 / billy
452 / 04/03/2020 / ulfm1
454 / 04/05/2020 / BVH
455 / 04/05/2020 / bobkido
456 / 04/05/2020 / osb40000
458 / 04/05/2020 / Tom E
459 / 04/06/2020 / nick779
460 / 04/06/2020 / brno602
461 / 04/06/2020 / kellyglanzer
462 / 04/06/2020 / cloggy
463 / 04/09/2020 / LumenWop
464 / 04/09/2020 / sleasys14
465 / 04/13/2020 / SilverHazeFlash
466 / 04/13/2020 / California_Prepper
467 / 04/13/2020 / CM2010
468 / 04/13/2020 / strayz
470 / 04/14/2020 / Kekuka
471 / 04/14/2020 / Blggg
472 / 04/17/2020 / paragon
475 / 04/18/2020 / stanmore
476 / 04/18/2020 / WV_Flashlight_Fan
478 / 04/20/2020 / arekm
479 / 04/20/2020 / Danthemanz
481 / 04/20/2020 / kal444
483 / 04/22/2020 / ggreen57
484 / 04/25/2020 / freethink
486 / 04/26/2020 / tekwyzrd
489 / 04/26/2020 / Blggg
490 / 04/26/2020 / mgracia85
492 / 04/27/2020 / Brawler1588
493 / 04/27/2020 / maildroid
494 / 04/28/2020 / Erion929
495 / 04/29/2020 / vandasian
496 / 05/01/2020 / severide
497 / 05/03/2020 / Qwibbles
499 / 05/03/2020 / Fogardebreogan
500 / 05/05/2020 / d00rkn0b042
502 / 05/14/2020 / oferreira
504 / 05/19/2020 / nydude
505 / 05/19/2020 / riffraff
506 / 05/19/2020 / O26Rcr
507 / 05/19/2020 / djsz
508 / 05/19/2020 / waxing twilight
509 / 05/19/2020 / Dheppner
510 / 05/19/2020 / FollowspotDude
511 / 05/19/2020 / mrwolf
512 / 05/19/2020 / bonegunner
513 / 05/21/2020 / joeangi
514 / 05/21/2020 / zoysiamo
522 / 05/23/2020 / Ragsy
523 / 05/24/2020 / Xebrecito
524 / 05/24/2020 / Noir
525 / 05/24/2020 / SKV89
527 / 05/25/2020 / Foghorne
528 / 05/29/2020 / Adam_R
529 / 05/31/2020 / flashycali
530 / 05/31/2020 / Niloticus1
532 / 06/02/2020 / Rsqweezy
533 / 06/02/2020 / VK-GX
534 / 06/02/2020 / SebaZ74
536 / 06/02/2020 / pthartung
537 / 06/03/2020 / luisgcan
538 / 06/04/2020 / bobofire
542 / 06/05/2020 / ichoderso
543 / 06/05/2020 / 1332332331
544 / 06/05/2020 / lukehale
545 / 06/06/2020 / iaknew
546 / 06/07/2020 / AvocadoCat
548 / 06/13/2020 / patchythepirate
549 / 06/13/2020 / Lux-Perpetua
550 / 06/13/2020 / Petroleum Lantern Guy
551 / 06/13/2020 / sueli428
552 / 06/13/2020 / apt323
553 / 06/13/2020 / Vbryanv
557 / 06/13/2020 / Xenon
558 / 06/13/2020 / XXX-Man
559 / 06/13/2020 / Royo
560 / 06/13/2020 / marioleno23
561 / 06/13/2020 / stepdown
562 / 06/13/2020 / Tredd
563 / 06/13/2020 / Speed2z28
564 / 06/13/2020 / Krisinpudding
565 / 06/13/2020 / Dickens
566 / 06/13/2020 / sledge0816
567 / 06/13/2020 / copperheaded
568 / 06/13/2020 / crazy.about.lights
569 / 06/13/2020 / Lol
570 / 06/13/2020 / Pistonsandgears
571 / 06/13/2020 / ben1680
572 / 06/14/2020 / Kingjohn
573 / 06/14/2020 / AguassissiM
575 / 06/18/2020 / h5550
576 / 06/18/2020 / Andyman
577 / 06/19/2020 / axim
578 / 06/19/2020 / nightshark
579 / 06/19/2020 / weklund
581 / 06/21/2020 / Plat
582 / 06/21/2020 / odriewniffe
583 / 06/21/2020 / Myke
585 / 06/22/2020 / xevious
586 / 06/22/2020 / Bradlink
587 / 06/24/2020 / sueli428
588 / 06/26/2020 / metroGnome
590 / 06/27/2020 / FrozenSTIFF
591 / 06/27/2020 / Lips
592 / 06/27/2020 / MauiSon
593 / 06/27/2020 / Randolph
594 / 06/28/2020 / jericho0o
595 / 06/28/2020 / Lazy-R-us
596 / 06/28/2020 / timbo114
597 / 06/28/2020 / Fastgonads
599 / 06/29/2020 / sac02
600 / 06/29/2020 / fluke
601 / 06/30/2020 / Friendlyfodder
602 / 07/01/2020 / redsuns
603 / 07/01/2020 / AndyMac2272
605 / 07/02/2020 / dddddddd207
606 / 07/02/2020 / MountainKing
608 / 07/02/2020 / badtziscool
609 / 07/02/2020 / Vbryanv
610 / 07/02/2020 / donthelegend
611 / 07/03/2020 / sixhundredmiles
612 / 07/03/2020 / dyates
613 / 07/04/2020 / Etsebjd
616 / 07/05/2020 / Illini2000
617 / 07/06/2020 / Ilmatic
618 / 07/06/2020 / VictorMarquez
619 / 07/07/2020 / tzmxxhh
620 / 07/07/2020 / DrLimp
621 / 07/07/2020 / schlauerlauer
622 / 07/07/2020 / Fonckman
623 / 07/07/2020 / Seeker1
624 / 07/08/2020 / ElFritoBandito
625 / 07/10/2020 / SciFiFreak
626 / 07/10/2020 / amishbill
628 / 07/11/2020 / ngiovas
629 / 07/11/2020 / maildroid
631 / 07/12/2020 / david_opp
633 / 07/13/2020 / DaveyC
634 / 07/13/2020 / dz12
635 / 07/14/2020 / caramba
636 / 07/14/2020 / 2Grumpy
637 / 07/15/2020 / Flitsmal
638 / 07/15/2020 / GDF
641 / 07/19/2020 / GuitarFreak027
642 / 07/19/2020 / jim_r
644 / 07/24/2020 / RugaL
646 / 07/27/2020 / bigm
647 / 07/30/2020 / kyledutton
648 / 07/30/2020 / Rdubya18
649 / 07/30/2020 / caramba
650 / 07/31/2020 / matik42
652 / 07/31/2020 / greymage
653 / 07/31/2020 / Jpons
654 / 08/02/2020 / ReManG
656 / 08/04/2020 / Kardolf
657 / 08/04/2020 / racnigel
658 / 08/05/2020 / joeangi
659 / 08/05/2020 / DAGG3R
660 / 08/05/2020 / whitecitadel
661 / 08/05/2020 / sukanta
662 / 08/10/2020 / fourbyfive
663 / 08/10/2020 / StihlMad
665 / 08/10/2020 / Midnite
666 / 08/10/2020 / 71k5
667 / 08/10/2020 / autodidact
669 / 08/12/2020 / wahoowad
670 / 08/12/2020 / rockville
672 / 08/12/2020 / Marc
673 / 08/16/2020 / Jonnor
675 / 08/16/2020 / maniakman
676 / 08/17/2020 / Mraz
677 / 08/17/2020 / Jalben
678 / 08/17/2020 / jzyg
679 / 08/18/2020 / Denis O
680 / 08/18/2020 / Aardvark
681 / 08/18/2020 / BatteryPowered
682 / 08/21/2020 / shutterboy
683 / 08/23/2020 / MKayze
684 / 08/23/2020 / F.i.l.a.s
685 / 08/23/2020 / LumenLucas
689 / 08/23/2020 / weklund
695 / 08/31/2020 / Sti.N.Gear.Usa
696 / 08/31/2020 / poskok
699 / 09/02/2020 / liquidrazer
700 / 09/03/2020 / Faring
702 / 09/06/2020 / SamuelTheShark
703 / 09/07/2020 / trigger619
706 / 09/07/2020 / gravelmonkey
708 / 09/08/2020 / pgenera
709 / 09/08/2020 / cohoer
710 / 09/09/2020 / TheAlchemist
712 / 09/11/2020 / izmarkie
714 / 09/12/2020 / kadete26
716 / 09/13/2020 / Merkur
717 / 09/16/2020 / niffer
718 / 09/16/2020 / heliosxx
719 / 09/16/2020 / scalpel_ninja
720 / 09/19/2020 / Dewalt101
721 / 09/19/2020 / Merkur
723 / 09/20/2020 / kellyglanzer
724 / 09/22/2020 / pfuender
725 / 09/22/2020 / neabue
726 / 09/22/2020 / Dickens
727 / 09/26/2020 / martytown
729 / 09/27/2020 / ReManG
732 / 09/29/2020 / bigblf
735 / 09/29/2020 / Ilikebiglightsandicannotlie
736 / 10/04/2020 / teryd1
737 / 10/04/2020 / lionheart_2281
739 / 10/05/2020 / Caleb
740 / 10/05/2020 / rdhood
741 / 10/07/2020 / Interested
742 / 10/07/2020 / Bake
744 / 10/09/2020 / lowhi
748 / 10/11/2020 / sleasys14
750 / 10/11/2020 / TheThreeLaws
751 / 10/12/2020 / ControlTheController
752 / 10/12/2020 / FBsLights
753 / 10/13/2020 / rogue2020
754 / 10/15/2020 / autodidact
756 / 10/18/2020 / leftfordead
757 / 10/18/2020 / woodyt
759 / 10/19/2020 / Sillen
760 / 10/19/2020 / LightBearer
761 / 10/19/2020 / drewski
762 / 10/19/2020 / DaveyC
763 / 10/19/2020 / Superslicknick
764 / 10/21/2020 / tvbi
765 / 10/21/2020 / Heavyopp
766 / 10/22/2020 / Kindle
767 / 10/22/2020 / emarkd
768 / 10/22/2020 / Uhman
769 / 10/22/2020 / Ozythemandias
770 / 10/23/2020 / Wusson
LT1-Mini-Project
(reserved 2)
LT1-Mini-Project
(Reserved 3)
LT1-Mini-Project
Some first designs of the driver
as discussed one with a red channel the other with a Turbo mode
Diameter 25mm with USB-port has resistors to charge directly on a USB-C wall adapter
TP5100 up to 2A fast charging with 5-18V input (not QC or PD, but good for direct connection to 12V solar panels)
RED 3+3+1 AMC
DD WW+3+3
LT1-Mini-Project
(Reserved 5)
goshdogit
goshdogit's picture
Last seen: 3 hours 25 min ago
Very nice! I love seeing your prototypes, Den!
I use my LT1 every evening and will definitely buy a couple minis.
Looking forward to more details and the introduction video! Thumbs Up
DBSAR
DBSAR's picture
Last seen: 1 day 10 hours ago
Thanks for the comments Thumbs Up
As we to get power outages quite often, the LT1 has lit many nights here, and i still use the first production one i received as my main night table light, running on moon or candle mode every night.
This new thread is dedicated to the LT1M Mini, which is the answer to the many wanting a pocket-sized, back-pack sized portable version for camping trips, and even be the little brother/sister to your full size LT1 Lantern. Big Smile
1stein
1stein's picture
Last seen: 24 min 12 sec ago
I’ll hold on until micro Cool
lotrbfme
lotrbfme's picture
Last seen: 4 days 18 hours ago
Awesome in for one in 4 years if I survive the pandemic Smile
puglife2
puglife2's picture
Last seen: 1 hour 3 min ago
DBSAR
DBSAR's picture
I will be doing a video soon on some custom built super micro lanterns, even one that can fit in your wallet, emit the same light or more of a candle 360 degrees , & run for 40+ hours.
1stein
1stein's picture
AWESOME. Hope you’ll link it on BLF
DBSAR
DBSAR's picture
I will, it will be in the main OP of this topic for the LT1 Mini, but will be a separate new topic for the other micro lantern projects.
agent80
Last seen: 13 hours 18 min ago
Woah! Wallet?? Never seen anything like that..
DBSAR
DBSAR's picture
Yes, sort of. The entire lantern in only 4.5 millimeters thick, uses a very unique remote-phosphor LED (very hard to find) that emits Warm white nearly 360-degrees like an incandescent bulb, can run from a single CR2032 Lithium coin-cell for 12+ hours brighter than a candle, (tested) then run for an additional 30+ hours dimming down to a moon light, but this wallet lantern has two slots for two CR2032 cells in parallel to double those run times, (or save one as a reserve back-up cell after the first is spent.) I have one in my wallet now. the video will reveal this “24+ hour wallet candle” when i create that topic. Big Smile
AEDe
AEDe's picture
Last seen: 15 hours 30 min ago
Driver of IF25 use noticeable PWM.
Could it be possible to transform ltmicro into handheld flashlight? It seems much more actual question than for lt1.
Also for small host it seems good to use main host as heatsink.
DBSAR
DBSAR's picture
we will be developing the LT1M Mini to use non-PWM same as the full size LT1 Lantern.
Greener
Greener's picture
Last seen: 1 day 9 hours ago
Interested
SIGShooter
SIGShooter's picture
Last seen: 2 hours 44 min ago
As with the LT I’ll be keeping the interest list for LT1M. Just post your interest in this thread and I’ll add it to the list.
Note that any interest posted in the prior mini LT thread was not captured so post in this thread to get onto the list.
Thanks
9mm/40cal/45cal bullets and large/small pistol primers available for sale in San Francisco Bay area
DBSAR
DBSAR's picture
Thanks
Thumbs Up Big Smile
AEDe
AEDe's picture
Thumbs Up Interested
litenutz
Last seen: 2 min 42 sec ago
Interested
DrDevil
DrDevil's picture
Last seen: 1 hour 1 min ago
Interested
agent80
Interested
taenzerwalze
Last seen: 10 min 33 sec ago
Interested
leo l.
leo l.'s picture
Last seen: 4 days 2 hours ago
Interested
Regards
Leo
ger-slash
ger-slash's picture
Interested
qandeel
Last seen: 1 month 1 week ago
Interested in 2. Hope they will offer nice colours,
 عُمَانْ
chris.zerocool
Interested
Nicolicous
Nicolicous's picture
Last seen: 2 hours 8 min ago
Interested.
Nico -.-
