Yeah, I also have the first version of the FW3A.
And I’m still getting intermittent problems like failure to turn on.
Remedied by removing the head from the body and replacing it, several times, eventually it lights up.
I’m afraid it’s like a firearm, has to be taken apart and cleaned after every use.
Well, it seems like peoples experiences vary widely. We have two FW3A’s. One from the first batch I guess, as I ordered the same day it became available. Also one from a later batch; that one has the modified two level momentary when locked. Both have been completely acceptable. I’ve never had either not want to turn on, or be uncooperative in any manner. Both are carried as an EDC, by two different people. They are used a lot, e-locked a lot, carried in a pocket not on the clip.
I have six FWxx lights. I’ve only had an issue with one of them and it was as you described. If the head was loosened or removed and then replaced it would turn on. After a couple failures to turn on, I took off the head and checked the contact ring on the driver side and noticed some excess grease had worked its way in there. Wiped it off with some IPA and it’s been fine ever since.
It is easy to start thinking all the lights are troublesome when you hear people say they have a problem on the troubleshooting thread. Just remember there are many hundred, maybe thousand?, FW3A lights sold, but only a few dozen have issues. It’s basically the same for all flashlights, cars, TV’s, etc… The percentage of defects or problems can be higher for some models compared to other models.
I’ve only have one early light and it acted funny at first until I figured out I have to loosen the head, then tighten the tail, then tighten the head. I’ve had zero issues since then.
I think this light might have a slightly higher percentage of issues compared to others simply due to the design with it’s tight tolerances.
So don’t let this thread trick you into thinking everyone is having problems. I try to think positive.
This o-ring is only to prevent the clip from rotating. I wonder if it was preventing you from fully tightening the tail to the body and squeezing the inner tube contacts to the switch?
I just got mine in the mail this morning. I bought it for a few reasons:
1. I reviewed the "Vote for the Best Light of 2019" topic thread, and saw it scored super high.
2. Most compact, high power, single 18650 light.
3. I like this friendly and helpful forum community, so I thought I should add another nice budget light to my collection, so I can feel more fit in with this forum community. (I have Emisar, Imalent, Manker, Nightwatch and Noctigon lights that I like and love and am excited about very, very much)
4. This light is recommended by leading luminaries of the Flashlight World.
5. Cost is almost free.
6. Zero body prints.
7. No frills, simple yet elegant, attractive design.
8. No pesky magnet in the tailcap.
Mine arrived in, has been in, and is stuck in "box of chocolates" mode. There is no way of knowing in advance what is going to happen and/or not happen if I click once while off, click once while on, click and hold when off, click and hold while on, double click while on, or double click while off.
Because I am late to the FW3A party, I had plenty of time to review the troubleshooting tips and tricks.
I did not loosen and re tighten the tailcap, because it is beyond hand-tight out of the box.
I tried reset by removing the head and holding the button while re-connecting the head. Click four times while on yields nothing. Click three times while off yields nothing.
At the moment: Click once from off to turn on = Nothing.
Double click from off = Sometimes turbo, sometimes medium power.
Double click from on = Turbo.
Press and hold from off = medium power, no ramping. I can not access any ramping nor any stepping function at all whatsoever.
Press and hold from on = Turn off. I can not access any ramping nor any stepping function at all whatsoever.
I have been senior global moderator for more than a few years of the official forum of the worlds consistently highest independently rated premium anti virus company, so I know, as was mentioned a few or so posts above, that troubleshooting topic thread means only a very small percentage of users see any issues.
I am all good/very happy with points 3, 5, 6, 7 and 8 above, so I am happy to add this light to my collection.
I noticed later model FW3 series lights have a retaining ring in the tailcap. This is to prevent the switch guts from falling out of the light if the tailcap is removed.
However, I noticed in my FW3T that this ring is VERY finicky.
Screw it in too tight and it seems to hold the switch PCB at a very slight angle resulting in poor connection and a malfunctioning light.
Screw it in too loose and it prevents the tailcap from screwing in all the way and the light does not work at all or malfunctions.
If you’re having problems with your light, one place to start is to remove the tailcap and try loosening and/or tightening that tailcap retaining ring until it works properly. Alternatively, you can simply remove the tailcap retaining ring. It isn’t necessary if you open the light from the front like you should.
That said, I don’t think this advice will help Richbuff. The behavior he reported (like press-and-hold for off) seems like it would require firmware reprogramming.
Nothing is glued in the FW3A. Tools shouldn’t be necessary. If you want to remove the tailcap, just grip it really hard and turn. If you’re having trouble getting enough grip try using a piece of rubber or grip tape for added grip.
Note also that malfunctions in the tailcap of the FW3A never result in a rattling tailcap. The inner switch tube can be misaligned or touching the wrong thing at the back without any rattle whatsoever.
Sometimes I wrap a rubber band around stuck parts to get a better grip without marring the finish. I’d bet the tail needs to be loosened or disassembled.
It’s only job is anti rotation. Some people don’t even use them. I don’t use it in my light. You might try a local hardware store. If no luck, maybe ebay.
I’m talking about the black o’ring for the water resistance. The one at the head is larger than the one at the tail. I can’t screw the tail cap enough.
Lumintop should send them as spare too. I’ll try at my local hardware store or online thanks!
edit: Now I’m thinking about put some silicone sealant. It will protect from water and prevent me from taking the tail cap out again.
