Features:
3A each slot ,12A in total.
Charge/Discharge/Capacity test /Repair
Automatically select the optimum charge current.
Easily choose current you want at manual mode.
Wide & High charging current choice: 0.25A /0.5A /1A/1.5A/ 2A/ 2.5A/ 3A for eachslot.
Show charging status in real-time like voltage ,capacity,temperature,time,current.
Enough space for 21700 battery, even button top 21700, PCB 21700 .
Top surface have a button top type feature to make contact in recessed battery
It is compatible with every type of rechargeable battery.
Support 4 slots charging independently without interference.
Automatically activate and repair “0 voltage”lithium battery.
Automatically calculate battery charging time.
Automatically calculate the battery percentage.
Charging protection, over-discharge protection and protection of polar reverse,shortcircuit protection .also, it can detect a broken battery.
Temperature control protection.
Keep your battery safe, most important,your lifesafety.
Intelligent power bank 5V 1A.
Certified by FCC CE ROHS.
After patiently waiting for two months (it was a pre-order, after all), it shipped. And unexpectedly, they upgraded me to DHL shipping! That was a nice surprise.
It just arrived a few minutes ago. I can wait to check it out. This will be my first analyzing charger
HKJ reviewed the S4+ including the repair function. He has a couple graphs but not much of a description. The fact that he didn’t have anything negative to say about the repair function leads me to believe that he approves of it. And I trust his opinion on the matter more than my own
That is a good point that HKJ’s lack of comments about Repair mode implies he at least didn’t have an issue with it. I would still love to hear some real world results from users though.
Mine arrived (from 18650 Battery Store) yesterday. So far I am VERY underwhelmed with how this charger handles well-used and/or older NiMH batteries. I will report more after further testing…
With most old, beaten-up nimh cells that has quite high IR values, not only the S4 but also some of my other chargers/analyzers will show really quick numbers and then terminate.
After using it with more cells and switching to Manual, I think the issue is the Repair mode always discharges at at least 500mA. My older cells must not be able to handle that rate so they just quickly ‘discharge’ — except they aren’t really being fully discharged like the charger thinks. When I try the charger’s Discharge mode and set the current to 250 mA, then I am see the results I had expected. It’s a real pity that the charger doesn’t give the user the ability set the discharge rate in Repair mode (and 500mA is the lowest it uses)!
