Ah, that’s a pretty neat design, Agro. Too bad it can’t be on while it’s attached to your keychain, but that would defeat the lockout benefit.
Remember that the clip switch can be clipped to any non-conductive material or to any pocket with no need for a magnet. In reality, the remarkably similar ones to my design are the cheap medical pen lights in which the pocket clips act as the switch. Those however don’t come on when you remove them from your pocket and you have to press the pocket clip down for activation…
I also missed the clap on/clap off and voice activation.
im thinking, work some workers, electrians ,plumbers that need to work in all types of situations, they could clip this in there pocket, and when they need a light, take it out and bobs your uncle, light!
Thank you. Wish to win and test this new idea… Good luck to all
And to the winner of this one (PHOUTON): Please comment about it as soon as it arrives to you and have time to try it. I am anxious to know more… Specially about how much time it works without starting to get dust/dirt in the contacts and make it flicker or even not to work properly due to accumulation of dust particles…
Reliability is excellent in my testing and that of the other users I sold my first ones to (friends/family). A buddy of mine has used one as his primary light as a mechanic for 6+ months and it has held up perfectly with only minor maintenance. I’m still EDCing the final prototype I made and have been for about a year now. It still works great after approximately (conservatively) well over 500 pocket insert/removals.
The pocket clips on Streamlights are bendable but it’s quite difficult to do so (they are well designed and very robust stainless steel). The aluminum body does start to wear down slightly at the point of contact over time but not so much as to cause a problem. If it ever did wear enough to cause a problem you could remove more anodizing and turn the clip slightly for a brand new contact patch.
I had made some prototype Eagtacs and found that the high current combined with the thin body worked well on the Titanium but not on the Aluminum (it was showing a lot of aluminum loss very quickly). The Problem that I ran into on the Titanium one was that it was VERY difficult to isolate the tailcap (it was unreliable).
This is why I believe some experienced metalergists and/or engineers could make this idea go far!
Also, fabric actually has a cleaning effect on the contacts. The only issue seems to be lint/fuzz on certain types of fabric, but on fabrics such as my cotton Wrangler ripstop jeans it’s a non-issue.
A specially designed contact with certain grooving and channels and/or dual contact points could virtually eliminate the lint issue.
Most of my questions and worries are answered with your extensive comment. Thanks!!
Obviously the aluminium is not as strong as other metals and obviously soon or later will show degradation…. But perhaps we could find a fix for that…
Of course, more powerful flashlights that need more amps will suffer more with that issue… But the main idea was that the clipswitch is designed for pocket flashlights… And most pocket flashlights dont require such high current…
