I dug up the green cell that came with my Cometa that I bought at Banggood. It’s the same exact color, but Vapcell Vappower brand 5200mah. That’s the weak one.
I really dont know much about the green HLY cell other than they are inexpensive. Hopefully someone can do some amp draw tests and see how it compares to known, tested cells.
The 26650 that comes with Cometa is Vappower (not Vapcell… lest they get angry…), I also have it, and appears to be a weaker cell (higher IR).
The HLY seems to compare similarly to the Liitokala Lii-50A (black) — at lower current drain (ie. when doing a discharge test @ 1A discharge current of a fully-charged Lii-50A alongside a fully-charged HLY 26650, they seem to track close to each other, at least at 1A).
Tried using the HLY and Lii-50A on MF01-Mini, seems to yield almost similar Turbo brightness (ceiling bounce, and with lux meter to compare).
The HLY 26650 comes in 2 types: beige and light green. I “guess” the beige one has a slightly newer date code than the ‘light green’ HLY (I’m just guessing the date code markings). I measure AC IR (using YR1030 resistance tester) of ~17mOhms for the HLY 26650. (for Lii-50A, I get different AC IR for different batch, but most are around 17-18mOhms AC IR when measured using the YR1030).
*re “date code” of HLY, only my “guess”, the last 2 digits of the 1st group of 8 alphanumeric characters is probably the year of manufacture (the ‘light green’ has “18” for 2018 and the ‘beige’ HLY has ‘19’ which probably means 2019 year of manufacture.
Just got them in the mail
I love this lamp with the 21700 Samsung 30
Only problem I ordered 4 by mistake (needed 3)
It’s a gun grey 5000k $56 shipped us Paypal no wait
3 day ship listed on eBay
Best light ever considering size weight using them for camping boat and with my dogs
I thank this forum for the great advice and review for this lamp. A true winner
Can u tell I am excited
I ordered a Ft03 so I could have a thrower. But, Bangood can’t find my order. So, is the mini a thrower like the Ft03? The problem I have is I got a bonus from work so I have to spend it or I have to give it back. Hmmmm. I’m just joking.
New Toys!
Made sure everything works (including aux LED). All is well for now.
Have 2 copper plates (Arrived before flashlights) that I will insert along with MX4 thermal paste and possible thermal pad in other areas.
Seems like button click speed varies between the 2 for activating various functionality. The sleeves work great as I can use 26650, 18650. Have not tried 21700 yet.
The aluminum with battery weighs less than the copper without battery. The copper is one hefty weight flashlight!
Has anyone successfully been able to change the thermal configuration for the step down? I been reading and watching videos on how to do this. But no matter what I do, nuthin has changed….light steps down from turbo after 10 seconds each and every single time. Any help is appreciated. Thanks all
