Osram CSLPM1.TG (aka white flat 2) is now available in higher 6P flux bin, that should be about 10% brightness increase compared to 5P (according to datasheet and previous measurements - about 1800lm @ 7.5Amp):
16mm DTP boards are out of stock, new batch of gen2 boards are expected by the end of March ( about 1.5 month later than planned because of virus thing).
Luxeon V 4000K is in stock again, CAT code is V13F (same Vf bin as 5700K so they can be mixed), mixing 4000K+5700K is added as option for all 4x and 6x boards:
Due to current situation, those boards will not be available for some time, 16mm 3030 DTP are back in stock, next are 3030,3535,4040 20mm Cu DTPs and 3535,4040 16mm Cu DTPs.
Depends on interest, but it's an expensive LED, additional problem is custom DTP PCBs have to be made and those have large min. order quantity, so I'm not sure it's feasible.
If you would just sell the bare led, people could buy the 20mm DTP SST-90 board from kaidomain. But I know that your policy is to always offer the option of the led reflowed on a board.
I’m amazed i remembered.
Going back to your point though it doesn’t have to be an MCPCB that’s sold with the LED, it could be sold with just a gasket, or something else for minimal cost. Wire, even.
