gchart. that’s about right unless your eyes are heavily adjusted like jon_slider mentions waking up at night. If the trit is a little more exposed it may be incrementally brighter too, some slots are pretty deep. the one’s i’ve poked into the rubber nub of clear clicky switch boots are just as visible as this green one when on a dark night stand.
trits brightness is somewhat additive
that is, more trits are more visible than just one
but still very dim, still not visible during daylight, but very visible when I wake up in the dark
imo Trits make excellent locators for a light on the nightstand, and they are entertaining to look at when visiting the porcelain throne in the middle of the night
trits cost does add up
it is not hard to spend as much or more on multi trit installs, than the original cost of the host
Those two pics are exactly the ones I’ve been looking at. I realize the effect may be exaggerated in those pics, but the LANs look stunning in them. But I’m scared of spending the ~$70 and never being able to see that they’re there.
I understand that they will never be visible in a well lit room and I’m good with that. But I’d want to be able to see them at night time.
for me, trits produce a visible glow, but when I wake in the dark, without my bifocals on, they produce a fuzzy glow.
I can NOT make out the clear outlines of each trit that we see in the photos… it is more like your second photo… dim and fuzzy, but visible… depending how good your eyes are I guess.
for me, this 6 trit button was a waste,
I could not see well enough to tell the colors apart, and I did not like that the layers overlapped and broke up the full view of each trit
Im much happier with the 3 trit button on the right:
I dont own a TiLan, so it will be up to you to share your tritted Lan experience with us
(its only money, you deserve it… lol)
Here’s a small trick to get a very slight amount more visibility from the tritium vial by removing the anodization in the slot (or get the bare aluminum version of the C01s):
I took this picture in a dark room - just automatic settings on the camera - the only thing I did to the picture is change the contrast setting.
This is the one beside my bed at night - my favorite, but almost too bright for my dark adapted eyes ( bad picture taken in a dark room )
On the CO1S the trit slot is very deep and in order to get the best visibility for the single trit I put a small sliver of clear plastic about 1mm thick under the trit to raise it close to the top of the slot. This gave a much better result than my early attempts.
turned up the contrast
I like your trit solution for the Original RRT-01 a lot
are those 6mm trits?
and if you did it again, would you do anything different?
Yes, they are 1.5×6mm. For my purpose I really only need 3 trits to make it bright enough for me in the middle of the night.
This light makes it easy to add from one to five trits around the tail cap as it slopes down from the center to the inner edge enough to completely encapsulate the 1.5×6mm trits in Norland 61 – making them difficult to damage.
(I do sleep in a very dark room and what I find bright might not be so for others.)
Got my red C01S yesterday and tried it with a Vapcell 10440, and its a pocket cannon at high, though it does get warm quite quickly. It barely gets warm on low. Anyone else using their C01S with a 10440? I plan to use it mostly on low.
Be careful with that! If you search this thread for 10440, you’ll find that some members have had luck with a 10440 while some haven’t been so fortunate:
I find tint of sst20 4000k a bit green and inconsistent if used indoor on night,also blue peak seem high.
If will be shave does Duv and CCT decrease for get a good warm tint?
SST-20 has bond wires on the surface. You either have to do a really shallow slice or risk messing up the LED. IMO I would just replace the LED if you that’s what you prefer.
Yes I meant dedome Led,will search correct procedure.
If too much hard,Led will be replace with a warmer sst20, but will cost like almost the entire light.
I have used mine with 10440 several times and it has worked well, but I have only used it that way a few times and for a short time, so I cannot guarantee that continued use will not harm the flashlight. There are several forum members who have damaged the driver by the use of lithium-ion …
I think that similar to Convoy flashlights that use SST20 4000k, the Sofirn lights that use SST20 4000k might have different bins, resulting in sort of a tint lottery… some may look OK, a few may have a more greenish hint… (I could be wrong here, but they don’t specify tint bins, do they?)
