It’s only job is anti rotation. Some people don’t even use them. I don’t use it in my light. You might try a local hardware store. If no luck, maybe ebay.
I’m talking about the black o’ring for the water resistance. The one at the head is larger than the one at the tail. I can’t screw the tail cap enough.
Lumintop should send them as spare too. I’ll try at my local hardware store or online thanks!
edit: Now I’m thinking about put some silicone sealant. It will protect from water and prevent me from taking the tail cap out again.
And what function does this rubber ring perform? Moisture protection? I spun off the shank and pulled out the tube with the rubber ring, then when I put everything in place, I couldn ’t tighten the shank, the clip was almost free to rotate. I was only able to tighten the shank well after I removed this rubber ring. What did I do wrong?
Which o-ring are you refering to?
If the one on the clip, it is for anti rotation as mentioned before. It can prevent full tightening of the tail cap on certain lights.
Moisture protection comes from the black o-ring near the threads.
Wait are there two white O-rings? One on the clip, and one on the switch tube? I may have re-assembled one of my lights wrong. But the switch tube is anodized, so it doesn’t short.
From your picture, the left-most white ring is in the wrong place. Lift it out of the groove below the threads and slide it down over the black o-ring. It should be resting on the pocket clip, between the pocket clip and the black o-ring.
When you screw on the cap, the white o-ring presses against the clip and prevents it from rotating.
The second white o-ring in the right of the picture is meant to help keep the black inner tube centered and reduce the chance of a short between the inner tube and the switch. However, sometimes it can cause problems. If your light isn’t working right, you might try removing that o-ring completely and see if it works without it.
I don’t think anyone really knows. It’s not for moisture and it’s not needed to prevent a short circuit. I don’t think it’s needed for centering the tube. It may provide a bit a tolerance and pressure to keep the center tube pressed against the tail switch.
It may be to prevent the inner tube from rotating. If it’s not there, the metal lip will press against the outer battery tube. Then if it twists it can wear the anodized finish and create a switch short. Just a theory.
The other white o-ring is just to keep the clip steady. For some lights it can prevent the tail cap from fully tightening.
Make sure to always tighten the tail before the head.
That’s how mine arrived, and I started fiddling with it because of loose clip and erratic operation.
I changed it as described above:
I tried that and it did keep the clip from rotating but screwed up operation of the light. All I got from engaging the tailswitch was a fast weak flicker.
So I moved the white ring back to “the wrong place” and the light’s behaving.
Firelight2 Thank you very much for the clarification. I did everything as you said and everything turned out, the flashlight works, the tail is tightened, the clip for the pocket does not rotate. Everything is fine. Apparently I have a flashlight from the latest releases and the board in the shank is tightened with a threaded nut, this is very convenient, since nothing falls out when disassembling.
I CANNOT lossen the tailcap on two brand new lights.
I received 2 x FW3a and 1 x FW1A today.
I cannot for the life of me remove the tailcap off two of the lights. Ive ripped holes in a bath towel, used pliers, rubber and hurt my hands.
I want to replace the battery tube with smaller tubes and remove the stock clip, this is my right. They shouldnt be tightening this thing so far its basically welded just because they cant design a proper light.
I know what im doing, let me do it. One of the switches also doesnt feel right and is causing it to not register clicks, i want to fix it.
Any ideas on how to loosen it?
Between this, the FW21 battery tube size issue im not particularly impressed.
