I am here to point out an issue which I often have to deal with. As most of you should he aware of, this forum has two editors: simple and advanced. The advanced is HTML, has all the bells and whistles, supports emoticons too but for some reason someone forgot to add an emoticon button to it (you can copy and paste their simple post editor :BLUSH: identifiers); the simple can most stuff a regular user may want. However, there is a problem whenever someone using the advanced editor wants to quote a message written with the simple post editor: it needs to be edited for it to look right because the advanced editor doesn't supports the encoding used by the simple post editor in most aspects (text format, images, links, etc.). And when someone mixes and advanced editor post into his simple post editor one, well, let's say I would prefer for the editor to be unified.
Also, please be aware that when you try to post a link which employs non-ASCII characters you must click/tap the link button in the editor. Failure to do so leads to broken links with the simple post editor, and/or formatting issues when super long links (full of tracking crap) are involved.
