- Cree XHP 50.2 led, over 3,500 lumens output
- Over 57,753cd beam intensity, over 480m beam distance
- Runs on one button-top 18650 or 18350 with the included short tube
- 29.5W, 9A FET driver. Parasitic drain while OFF is ~27 μA.
- Anti-reversed design, prevents reversed battery installation
- 43 mm ID, aluminum, smooth finish
- Aluminum with Type III hard-coat anodizing
- Tactile with back-lit rubber boot
- Equivalent to IP68, underwater 2 meters
- Size: 50 mm Ø head x 132mm length
- N.W.: 150g without cells
User interface: [1] Default Intuitive Narsil smooth RAMPING UI. Instant access to a 2.5 A TURBO mode is also provided. [2] Conventional discrete level MODE-SET UI is available. [3] MOMENTARY mode.
