Not sure if I ever answered this - might have missed. it. I'm 100% in on Anduril now, was easy to port to Windows Atmel Studio, for me that is, and since adding a couple features like calibrating the voltage reading and tweaking up the max temp regulation setting, it's working out well for me. Also it's got decent flexibility re-configuring I/O pins, which Narsil used to have the advantage of. So a laundry list of features I wanted to add to Narsil are already there in Anduril:
- wanted to dump the fixed modes, and make the UI more like ramping -- already done in Anduril
- my had-to-have feature was calibrating temp and voltage,and Anduril had the temp calib and was easier to mod Anduril to cal the batt voltage
- better support for AUX/switch LED's - already there in Anduril
- add support for the 16 KB MCU's like the 1634 - again already there in Anduril
Other things I'd like to do/have:
- support for 2 e-switches (got a couple lights to mod, waiting for that), but need a "smart" usage UI to take advantage of them
- better multi-channel output support. I got a SD Mini II working with special version of Narsil, where the side LED gets a 7135 and the main LED gets the FET. The UI could be done better though, and again, I think Anduril would be the better option, specially with a 16 KB MCU. I hacked up a FET+1 driver to separate the output of the 7135 from the FET.
[quote=WTF] Has anyone had any luck finding a spring for the driver? The closest one I found was at Kaidomain and required cutting down. [/quote]
Does this mean you have one of these, or are making one? Wondering if "loneoceans" is far enough along to release it in some form? I'm definitely interested buying a couple, either parts or assembled.
