The Convoy 4-mode driver uses off-time memory (as all lights should IMO) so you can flip to a mode, immediately turn the light off and it will be saved as long as you don’t turn it back on for a couple seconds.
That’s no good at all since you can’t use it tactically. That’s just a deactivated form of “long memory.” Down with “long memory.” Needs a separate mode switch.
swap to convoy 3 mode ramping driver if you need tactical. It has no memory and you can program it to all high.
Plus the mode change is so tight it deliberately needs fast clicks to change mode.
I have my solarforce forward clicky to med>high>high and it’s been good for me
but of course if you are in tactical situation and you tap your lights for more than 5/9 times, you’re better off with reputable lights
Hello. Please tell me Convoy M21C, M26C have 2300lm at 100% mode in the description, why is it 1550lm in the photo 100%? Sir Simon Convoy usually provides true data. Sorry, I couldn’t understand the subtleties of the review correctly, or these are my difficulties with the translation.
I measured 1550lm at 10s of shining, max brightness could be 1700lm, I think.
Now Convoy launched M21C XHP70.2, so if you need more brightness, this is the way
Mocarny, спасибо за ответ, я написал в Convoy, и я обязательно закажу другой фонарик M26C с XHP70.2, когда они сделают драйвер для 12 групп, у меня уже есть M26C sst40. Спасибо за ваш совет и ваш отзыв.
