I need this in my life… Coupon still available?
Coupon code please
Coupon reactivated. 5 colors to choose from now.
Interested in the group buy coupon,
still available?
Replied. [quote=bbuuu] Interested in the group buy coupon, still available? [/quote]
Ordered thanks freeme.
Group buy coupon please, with diffuser and holster.
Ordered !! Thank you very much
May I have 1 coupon please?
Interested in the group buy coupon please.
Sent.
I missed out earlier, any chance on the coupon now? Thanks
Replied. [quote=Itsme] I missed out earlier, any chance on the coupon now? Thanks [/quote]
Thanks Freeme, got a blue 5000K
Been thinking about this one, any coupons left? Thank you!
Would like to get with holster and diffuser as well
Thank you so much! Cheers!
You got mail.
I may be a bit out of touch these days, but can someone tell if the overheating and quick lumen dial down has been resolved for MF01s mini? Also I saw someone was offering copper heat sink cover plate separately. Is this still a separate thing that has to be separately installed or do the stock models now come with this copper cover plate ?
Thanks !
Hi everyone, my first post here. I just read all 49 pages of this thread, quite the journey!
I ordered my first “non-typical” light! Should arrive in the next few days. (MF01S Sand 6500K ordered on BG)
I saw some posts and threads that advised pre-use actions ranging from cleaning to led-reflow and repaste, to ensure it does not burn LED’s due to low thermal conductivity from bad solder job.
I have’t taken apart any flashlights before, but have some limited experience with a soldering iron etc.
I was hoping some of the experienced users could give me advise as to what you think I should do before first use:
1: Disassemble main components and clean with alcohol?
2: Lift LED board, clean factory thermal grease, and apply high end CPU thermal grease? (Non electrical conducting Grizzly Kryonaut)
3: Attempt to reflow LED’s. (Very scared of this)
Also, I already bought 4 VTC6 flat top batteries, planning to remove the reverse polarity protection rings (If they are even still included with the light?) and just being VERY careful when inserting the cells.
The brightest light I own right now is an Olight H2R that I edc, so looking forward to some “real” power!
Thanks in advance,
Cheers
I would just use it normally.
Don't fix something that's not broken.
Instead, simply give it 5-10mins visual inspection to look out for:
- Loose or missing parts for springs and connectors.
- Perform continuity test for battery carrier/ compartment.
- Condition of flashlight threads. Clean off any residues to reduce wear and tear.
- LEDs for dirt, burn marks or chip off parts.
- Solder joints leading to mcpcb, and leftover solder blobs which might potentially cause short-circuit.
Thermal paste upgrade doable but only if you are very keen to push the limit of the light and some spare time for it. Probably it is about 20mins job?
I am quite sure less than 1% of the buyers would attempt to reflow of those LEDs.
