There are 2 separate settings to contemplate. The first is the Aux LED state (off, low, high, flashing) and this is changed with 7 clicks. The second setting is the color. This is accomplished with 7 clicks but hold on the 7th. The aux leds must not be in the “off” state to change the color. They must be on low, high or flashing.
First thing you should do is get the aux LEDs in the “high” state. From there, you will press 7 times and hold on the 7th and then keep holding until the color you desire is reached. There are 2 color settings where the leds are changing colors one of which will have it just cycle the colors, the other is a battery check mode and will change with the battery charge level.
“…The aux leds must not be in the “off” state to change the color. They must be on low, high or flashing. …”
Many thanks. Fulfilled this requirement and the opportunity to replace the color
Well, this thread has caused me to order one in cyan (I’m a sucker for blue and this is my first non-black/grey light). I’ve got a Rofis MR70 as my EDC light for work, not sure if this will replace it or become a “household use” light. Looks too nice to get it all dinged up. Now I have 2 lights I’m waiting for (BLF GT90 is the other )
I ordered this flashlight from Hank and got it in record time (12 days) very pleased with the build quality. I ordered my batteries from someone sees and they are at least 14 days away…Any other recommendations on 26650 batt? I ordered the Liitokala 5000mah 50A. I was looking at some keep power 5200/15A, will these be sufficient? I will order these in a 24h in home service because I want to play with this light and don’t want to wait 14 days till the Liitokala’s arrive……Any other recommendations? What would the minimum maH be and the minimum Amperage?
Where were you able to find Shocklis in Europe? I’ve been looking around forever, to no avail. Nkon doesn’t have them.
According to HKJ’s tests 5500 Shockli are hugely better than the much praised cyan liitokalas. Much higher capacity and higher current too.
In another thread, one of the gurus said the D4S XP-L Hi draws 13 amps on turbo. So I just use a Shockli 5500 battery and it seems to do fine -even though I abuse turbo regularly. The cell under the wrap is the PLB-55A and it was in other brands like Keepower and Vapcell. Someone said PLB stopped making that cell. But any high capacity battery rated for 15 or 20 amps will be fine and will provide a longer runtime than a high drain cell.
the best is using as high capacity as possible… im using in my d4s efest 4500mah high drain because at the time there wasnt any other batteries with similar capacity, if i was to buy today extra i would get some keeppower 5000mah or similar.
They say they’re 6 amp discharge current. Since shipping was like the price of a battery I ordered 3 of them. I don’t have any other 26350 lights but I’m sure i will at some point (:
I need to get a box to organize all my batteries. What do you guys use?
I ordered 2 supposedly 10amp 26350s from Mountain Electronics a while back for my E10. Obviously the E10 doesn’t pull 10 amps so I don’t know if they a really are, but that’s another option.
Hi, I have both D4s and D4sV2 with the same leds, XP-L HD V6 3D, but the ones in the D4sV2 are colder, like 6000K maybe? Can this be a variation over tints in same leds or may I have a different led version?
In the boxes both of them state the same leds.
D4s left, D4sV2 right, both with fresly charged Vapcell 26650s.
Looks like the same CCT to me but the D4Sv2 has a much nicer tint. Greener tints can tend to have the effect of appearing as a lower CCT than they are.
Tint is kind of a lottery as to what you get, and it looks like you got a good one with your D4Sv2.
