[♛ Group Buy] Convoy M21C and M26C XHP70.2 Thrower 21700 Flashlight Group Buy (3 colors) - Deal is ALIVE NOW!
Interested.
Any more information available? Lumens, throw… tint, CRI?
What’s the difference between M21C and M26C?
Brightness: 4000lm.
Throw: unknown
Tint: 3000K, 4000K, 5000K, 6500K
Bin: unknown
M21C > 21700 (slight updated design)
M26C > 26650 (appearance kind of resemble with old X3)
Thanks for the clarification.
Now wondering how it compares to the M3. Driver and UI description let me think it’s the same driver… and i could not get used to it because of the long press to change mode which made cycling through modes slow and fastidious. I guess i got spoiled or touched by Andùril. Do you know if Simon updated the driver?
Interested
Will M26C fit 21700?
Probably not, M26C is 8mm shorter than M21C. Moreover, M26C only allow unprotected (short) battery type.
No. But if you unscrew the tube from head 3mm or more it work, no waterproof.
Tested on my M26C sst40 and Sofirn 21700/4000 from C8F (flattop unprotected).
I’m down if I can do Bossetti driver (is that what it is called?)
You probably mean Biscotti as available on he S2+.
Not sure it can handle a XHP70.2.
Interested in one.
Biscotti driver for XHP70.2 will be available soon according maker and also OP reflector
Yup, i heard that news too.
Is it possible to disable memory mode? If so I’m in for one.
Order placed.
Thx for the help.
WOW!
So, I will wait for the M26C/XHP70 with Biscuit driver!
ah yes, the famous biscuit driver
Best with coffee.
Sample has arrived few hours ago.
Show us!
Coming coming!
Can someone confirm if the M21C and M26C are the same light just threaded for different diameter battery tube? Or are there differences in head/reflector shape/size? If not, all things being equal, the performance between the two should be the same?
