Thank you for the excellent review. I was originally planning to wait to order the KR4 w/E21A LEDs, but I’m glad I caved and got one with SST-20 4000k FA3. I love the KR4, but I doubt I’ll buy the E21A version. The FA3 bin SST-20s have good enough tint to my eyes. If I’m going to downgrade output by over 50% I want a beautiful tint and beam pattern with decent efficiency. This one unfortunately has none of the above.
Hank did say he would offer multiple CCTs, wonder if 4000k or 3500k would look nicer with the stock optic? Efficiency unfortunately will be worse I’m assuming.
I am familiar with the optics thanks, I was talking about E17A emitters. E17A is the smaller brother to E21A so is throwier. Under a frosted optic I was proposing that they could have similar throw to the E21A with a clear optic but still have the same benefits of the blended tint a frosted optic would give.
Interesting. Did you have the aux LEDs on high mode?
It seems like it could flip between two colors if certain conditions… like if the voltage was close to a threshold, the aux LEDs were on high, and the higher of the two levels had two colors turned on instead of one. The way that could happen is:
Battery measures 4.11V, so aux LEDs turn purple (R+B).
Red+blue aux LEDs use more power than just blue, so voltage drops.
Battery measures 4.09V, so aux LEDs change to just blue.
Blue uses less power than red+blue, so voltage increases a little.
Repeat from step 1.
IIRC, it checks every 8 seconds, so it could change colors about 8 times per minute. In sleep mode, it wakes up very briefly about 8 times per second to handle the blinking aux LED mode… so the animation can happen at 8 fps. Every 64 frames though (every 8 seconds), it turns on the voltage measurement circuit just long enough to get 2 samples (the first sample is junk, so it needs to read twice), and then it checks the result and decides whether to change the aux LED color. If it’s below 2.9V, it turns off the aux LEDs no matter what mode they’re in.
I don’t have a way to measure it directly, but if my math is right, the entire process should take about 1 millisecond every 8 seconds.
Any idea when the E21 emitter version will be available for sale? If it’s going to be soonish, will wait and get both the K1 SBT90.2 and KR4 E21 at the same time.
Also, on the intl-outdoor site’s search bar if you type in D1S, there’s an interesting suggested autocomplete for “37D1S v2”. Sure would like to see that come out soon.
Our E21A LED package is stuck on the way for long time due to the virus issue, not sure when it will move, so, we are not sure when it can be offered. The 10623 optic will be default optic for the KR4 E21A version.
Mine will hopefully be here tomorrow. I need to get some 18350 cells, has anyone verified the max length yet? I would like to get a protected cell to avoid over-discharging if I forget to not use turbo. Assuming turbo for the xpl version draws more than an 18350 can handle.
Using turbo doesn’t somehow disable the light’s built-in LVP. There might be protected 18650s that could handle the drain from a D4 on high or turbo… but they will be rare and probably expensive. No protected 18350 will be able to handle the higher output levels without tripping the protection circuit.
I’m not even sure most protected cells will fit a D4. For kicks I checked if a Wowtac 26650 (flat top, protected) would fit my D4S and it was too long (wasn’t going to risk crushing something by forcing it).
Sorry, that is what I meant originally, current draw. I would rather have the cell protection trip and be annoying than damage an unprotected cell. If I can’t find one that could handle the current without damage.
