Always amazed at what you come up with
Very cool modding pinkpanda3310! The RGB LED idea that you came up with is ingenious.
My dream too ” PP ”
There are many CNC Routers for sale, but you need to research this for several months before buying one. It is possible to make some money on the side with one, but it will take time to learn many things. A rotary 4th axis will need to be added for flashlights and the table will need one corner cut out to allow for vertical milling for threading and boring. You will need software that is free for Hobbyist from AutoCad Fusion 360, and learn how to use it before buying. Art programs can be found free as well, and are needed to create “step” files for the Fusion 360 to read. Also its best to understand all the details of the CNC mechanical and electronics, as adjustments will be necessary from setup onward.
This all sounds complicated and it is at first, but the more you learn, it gets easier. The rewards are definitely as big as your imagination applied to making things.
Here are 2 that I would buy and will one day.
You have done it know PP.
That’s some awesome looking work, way to think outside the box.
Can’t wait to see how this turns out.
Only now I see that the LEDs are RGB…
I see only 2 traces on that makeshift PCB. How does it work?
Very perceptive Agro. These leds are slightly bigger than your average single colour aux led. AFAIK some need 4 wire control (rgb and ground). These ones however have an onboard controller so only power is needed. There were 2 types of colour patterns that I found. One is a quick three colour change (rgb) and a bit of a flash then repeat. The ones i’m installing are a slow colour change like a lava lamp, exactly the same as L4P rgb switches. Also just like the L4P switches the 6 installed in this light will start in sync with each other but will quickly go out of sync.
No, trying to improve another man’s work is not sacrelige. But putting a tattoo on a beautiful woman is.
Thanks for the explanation.
As with everything else about this light my first attempt failed… The lube I used didn’t actually make a good bond breaker. However cling wrap worked a lot better. I got some wrinkles in some of the windows and when I tried to clean the inside shelf with a Dremel I put marks on the inside of most of the windows
I wired everything up and… IT WORKS… well sort of… I made a slight oversight with driving the aux leds, there’s no resistor so they are way too bright So can anyone give me hints and tips on how to reduce the power? Negative side of the aux is just grounding through the host. Positive is connected to the main led + which is straight through to the battery +
Put a resistor inline off the + contact…lead on the other end of the resistor
Great! I was hoping it’d be nice and simple like that. Thanks KawiBoy
:+1:
How abot using transparent adhesive tape to prevent epoxy leaking? You could just leave it in place after epoxy sets.
Wow.
Good thinking KB1428.
I’ll take it. PM me your PayPal info.
Since I blocked the holes externally the tape would be seen so would need to be a very neat job of cutting away the excess. I’ll stick with what I’ve done. Thanks for the suggestion though.
Sold for $5000 Thanks mate :innocent: It’ll cost you an extra $1 if you want the battery and charger package :smiling_imp: :laughing: :laughing:
Sold? $5000.00. If your in the US thats about $5.00 to you.
I was going to offer $6000.00, my wife a cat and two dogs.
Patent it or you know this will appear on the next FWXXXXXXXX lol!
Very impressive PP. I likey!
This also got me thinking (happens)…… ok, so a while ago whilst in a £1 shop I saw these xmas lights, powered by 2xaa’s.
I got them to fit out my lego r2d2 and millennium falcon (which they do fantastic) - I just found 2 spare sets - they are white, and a coloured set (which are white with blobs of coloured resin on)
the leds are already mounted on 2 protected wires! lucky! I am thinking I could use these somehow like you did?
What do you think?
Lol, that would be flattery :innocent: It’s been nearly 2 years since I made the holey tail but it looks like nobody in manufacturing liked that idea :person_facepalming:
I have something similar to those lights you pictured. I imagine it’ll be quite some effort to shorten all those wires if you are poor at soldering like I am. Would be interested to see it if you do something with it though
Thanks for the offer Moose but one wife is enough for me
