I ask them!
Hi Martin, have you by chance been able to contact them yet?
TThank you,
Todd
I did not get an answer yet
amutorch XT45,
SST20 5000K will ship next week
XPL HI 4700K led still cannot be ordered now;
XPL HI 6500K, shipped
Any word on the sbt 90.2?
if i had infos i would post them :(
€dith saysyyou can look into the page linked in my signature for another source (slightly higher price) ;)
Updated on 05/15
Grey has been discontinued. Please the friends bought the gray version contact customer service to change to black, or ask for refund. The black version will be shipped next week.
Some lamp beads are difficult to order recently. So sorry to keep you waiting.
Hi Martin,
Thanks for the update.
Todd
The link takes me to a price for $114 ?
you need to use the code in checkout to get the discount ;)
I have one, just tested it, it gets HOT!
It stepped down to low at 83 DegC !
From turbo to low? Can you tell us more about it? Beamshots or performance figured thanks
Doing runtime test right now. Did some measurements this afternoon, it draws 15,4 A on Turbo and does almost 5200 Lm at startup.
The thing is, i did some beamshots, but apparently on high, not turbo. I just found out doing current measurements that it needs a double tap when ON for turbo. Otherwise it just cycles L M H.
It looks like its regulated at 60 DegC after Turbo stepdown, since output is rising again and almost stable 60 degC now.
That’s super helpful, Yokiamy! Looking forward to runtime data and any other details you can share. This thing is pretty attractive at $60.
Where 100% is about 5200 Lm (5180 on my Lumen tube, but dropping quickly)
tested with a purple shockli 4550 mAh
Thanks for the test! Seems like the thermal regulation could use some PID improvements…
Can you tell if the turbo instant drop has to do with the driver or the battery?
i think it’s temperature related, probably temperature stepdown, since it gets very hot.
Let’s see some photos of the light and some beamshots! I am impatiently waiting for mine to show up. Would also like to see some photos of the inside of the light head to see what driver swap options might work.
Interested. Is this deal still active?
shop says sold out...
