You’re probably thinking about the Northeast Blackout of 2003. Basically, due to poor maintenance and negligence, one supplier experienced a series of failures that caused their system to shut down. Since, their computers could not adequately detect and notify them and other systems of the situation, other suppliers lines became overloaded and started tripping out. This led to a cascade of all, or almost all, of the Northeast Grid shutting down.
Outside of this failure, most of the USA and Canada power grid’s reliability is probably on par with what you’re accustomed to in The Netherlands. For example, in North Carolina, most local outages are from trees being downed during a strong storm. Likewise, large outages are typically caused by hurricanes and ice storms. Depending on how many outages occur from a passing storm system, restoration usually takes from a few hours to the next day. Larger events where outside crews are called in, restoration may take a few days; and for some, a few weeks.
Forest fires are the biggest culprit when you live in beautiful wooded country. They can take out miles of poles and wire, but we see more steel poles being placed these days. Storms can cause havoc too, but after the town of Paradise was destroyed when malfunctioning electrical equipment started a forest fire, they have been removing trees near the lines for many, many months (and still are).
So we have been having at least three outages a year, sometimes triple that. Everyone owns either solar or a generator. The worst ones will last for days, but some are just for hours. Still, I will not move back to a city for better power and worse lifestyle. And now we might start having fewer incidents with all the improvements.
They’re very rare here, we haven’t had one in quite a few years. Every couple years a portion of our road will loose power due to a localised failure, but the distribution company start digging up the road within an hour of it happening so they never last long.
I can’t remember the last time power went out. It has been years. Anything built in Las Vegas after around 1980 has underground power lines. We get winds as high as 70 mph occasionally and the only homes affected are older ones with regular power lines mounted on wooden poles.
Here it is very unusual to have power outages. When it happens, normally is due to some heavier storms, but even then it doesn’t last long!
But that is always a good time to play with flashlights
Over here we don’t have (there is only one part left where we still have those; Krimpenerwaard. Total length of 37,5 miles/60 km) above the ground low voltage (<110kV) networks. I think it mainly has to do with us being a small country with a large population density. So there are nog outages because of poles being downed
Where I’m at here in FL, our Co-Op does a decent job. Power has only had prolonged outages from hurricane hits. Irma took us out for 10 days, which was the only significant interruption.
I do have a really sensitive re-closer in my network close by that seems to trip just about lightning strike, and knocks us out for 5 minutes, 8-10 times a storm. But I have all the pertinent necessities on UPS systems, along with whole house surge protection.
When demand for power is high they switch us off 2-4 times a day for between 2-4 hours at a time. Thanks to the Covid 19 crisis it seems power demand is lower than normal at the moment.We have not had any outages since the beginning of lockdown.
Midwestern Brazil, Pantanal region. Haven’t seen a blackout in over two years, at least not at home. The grid of the university I work at is complete trash and constantly browns out or has voltage dips that make lights flicker (so much so they constantly burn out, CFL bulbs barely last weeks so they switched to LED) and computers reboot, though proper power outages that last for more than 5 minutes are also rare.
Power reliability here is pretty good. No issues in my neighborhood since I bought the house in September. 2013-2016 I lived in an older neighborhood (homes from 190x) with overhead lines, and it was worse. 2016-2019 I recall two outages, both for only a few hours, and the result of some sort of random crap like a tree falling or a car crash or something.
They do pretty well considering the range of weather. It can reach mid-90s (35C) in the summer and as low as –2 (roughly –19C) in winter, and storms with high winds in between.
In general, though, a lot of this country’s infrastructure is aging and not getting the upkeep it needs. “If it ain’t broke, don’t fix it” should not be the strategy for infrastructure maintenance… But everyone wants lower taxes, so here we are.
Just got a notice that power will be cut all day for pole replacement. A steel transmission pole has been laying by the side of the road a few miles downhill from us, so that might be the one. But a neighbor’s notice read one day difference, so it might be two days?? In the city they used to set the new pole and “hot-stick” onto it, but up here there is a greater potential for destruction (forest fire) I suppose. Or maybe they stopped hot-sticking because they drop the lines too frequently, I saw it happen once and it caught a building on fire. Dangerous stuff. If it goes into the late evening my LT1 has charged batteries!
In southern Ontario, the only extended power outage I’ve lived through was the 2003 blackout. Aside from that, maybe a few hours once or twice for idiots hitting distribution infrastructure. My mum lives in a more rural area and has lost power for days at a time due to weather taking down power lines.
Portland - very rare we ever lose power. Last time was perhaps 6 months back, a car took out a pole at 2 AM. The previous time may have been a winter storm 6 months previous.
Coast small village we go down on weekends and approx 85% of the times I start the day by resetting all of the LED clocks. The clocks on the range, the music player, microwave are all blinking and off. The timers are all off as well. Clearly power went out during the week, can’t say how often. It would be a rare month where the power had not gone out more than once but I confess I have not tracked it.
I'm getting quite a bit out of it by seeing the variety of answers, especially when combined with people's locations. It's a nice reminder to myself that I'm not crazy -- power reliability in Florida is pretty poor compared to other regions and that the precautions/planning I do as standard in Florida is complete overkill for projects we have in other areas. The concept of going a month without a power problem, let alone 2 years, is mind-blowing to me.
I've seen some people mention cost of electricity vs. reliability. The US cost per kWh run $0.083/kWh to $0.373/kWh. Florida averages about $0.12/kWh. There's plenty of extra fees and taxes on top of that. Using Florida as a guide, there's NO correlation between the cost of electric service and reliability. Duke Energy is one of the most expensive energy companies in Florida and has some of the worst reliability, bar none. Almost all self-inflicted, like when they decided to stop trimming trees for a couple of years to save money. Florida Power & Light (FPL) has a well-documented history of neglecting their grid, with 50-75 year old wooden power poles decaying around the state. To FPL's credit, they have been making decent progress on replacing and upgrading their grid over the past 10 or so years. Still a long way to go.
As far as non-profit/municipal owned vs. investor-owned, I definitely see better reliability with the municipal-owned/co-op services over investor-owned ones, at least for day-to-day. When it comes to hurricanes and recovery from them, the investor-owned ones seem to be up quicker, minus Duke.
Interestingly, hurricanes have been very good at improving long-term reliability here. As each hurricane takes out more neglected grid, the replacement grid is better and stronger, and the temporary linemen on loan to us from across the country do an amazing job of making sure things are done right the first time.
