TA, gchart and djozz, thank you very much for your input on my questions!
I didn’t realize these leds are larger than the other “typical” LEDs!
Still, I guess I can mod an optic to make them fit Or…maybe I can use them just in reflectors!
BTW, I know that OP reflectors are probably better for these, but do they “perform” well with SMO reflectors? My Tool AA lights could benefit from an improvement if they are good for SMO as well.
Once again, thank you very very much for the replies
Ahh, sorry! I understood it wrongly. My brain processed “dome” instead of die! Ok, so if they fit will, I guess I won’t have problems with that! Also, I will probably use some optics such as 10511 or 10508 (floodier) so it will be a “wall of light” per se!
Thanks for the clarification!
And also for the info on the small SMO reflectors ! I may have a winner then I do like the Luxeon Leds, but after seeing what these do…I definitely wanna try them in other lights
The last emitter swap I did was in a tool ti AAA. Turned out pretty good. I then swapped one in the brass tool AAA and shaved the LH351D.
I liked the shaved version better, actually I haven’t found anything yet that shaving this led didn’t look better in. I also built a triple in a RRT-01 and used the KD triple optic with shaved LH351D’s, turned out very nice. Wasn’t as nice with a carclo, too floody and the KD optic seemed to make the tint more pleasent.
I knew the Samsung from the TLF Wuben E05-I and found it to be ugly greenish.
Recently, I ordered a couple of 2700K and 5000K LH351D from Sofirn and today implanted one of the 5000K LEDs in a C8 (BLF A6 driver, OPR, Manker MCPCB). What a difference! Those 5000K Samsungs from Sofirn are mostly neutral.
Do they have multiple bins at this color temperature, are there production specific variations or was there an update? I’d like to order more to equip a BLF Q8 with them, but would like to ensure they are still of this quality.
Worse case, you could probably shave the dome off the LH351D. This will not only aid fitment if there is interference with the optic, but it will drop about 500K in CCT (5000K becomes 4500K), lowers DUV, and makes it less floody. You’d loose a few lumens though.
