That is U6 bin.
Question:
Are the tubes identical to the KR4?
That is U6 bin.
Yokiamy: freeme:Wish there is a XP-L HI CW to compare with.
The 3A which is in the pictures wouldn’t make a huge difference over a 1A, the differences are minimal.
Forgot about that, cree’s datasheet states a difference of 100 Lm between the U6 and V6 at 1050 mA, so it will be at least 400 Lm more
i need one of these…thanks for the pics!
Don’t take this “U6-3A” too serious. That is the emitter that I’ve ordered, but you know… Chinese sellers write stuff in their description, but you might receive something else. But I don’t think you will get much more with only 2.8 A in the C8+ host with 8*7135. The C8+ has definitely the worst intensity in this comparison although it has the bigger reflector.
I think the KR1 W2 with 18350 tube is a really good EDC thrower.¹ 100 kcd, really small and 7.5 A should be fine with high capacity 18350. I use the KeepPower 18350 1200 mAh which can handle 10 A. And the capacity is more than enough because most often you’ll use a (EDC) thrower just for a short time.
¹ As long as it works! See 21700 D4KTi COLORFUL version is available - #1633 by SammysHP
Thank you for this comparison! I just ordered the NOCTIGON KR1 (W1 (Osram CSLNM1.TG): 900lm, Lux : 110,000cd)
This does not make it easy to not buy something shiny….
Great album! I have the same FT03 and its much more powerful (but much bigger too!).
In this album I compare a XP-L HI 1A CW with the KR1 W2
Great beamshots. Thank you for sharing.
Nice beamshots.
Thanks for the nice beamshots ……
And thanks for answering my question with respect to the possible difference between W1 and W2 with respect to which one “appears to be colder” ….
Martin
Just pulled the trigger on a W2 thanks to your excellent post!
I want to get the KR1 but it looks…too…not manly enough.
Manly enough ? KR1 in black is just a tube like every other light in its general size…
Has anyone compared the KR1 with the Manker MC13? The MC13 throws 20% further, but is a bit bigger. Still in doubt which one to get
There was also such a choice. I needed the option 18350. As a result, I ordered the MC13. In favor of the choice: price (ordered for $ 46), longer light length, better equipment. I like Manker design better. Only better handling is in favor of the KR1.
MC13 has TIR vs a traditional reflector in the KR1. Different beam profile and use case IMHO.
Wouldnt it be more apples to apples it the c8+ ran an OSRAM as well???
¹ As long as it works! See KC1 keychain light is available now - #1633 by SammysHP
Nice comparison!
I think so, but the C8+ with Osram LED was not available back then (and is still only available from Neal AFAIK) and the FT03 uses a big SST-40.
Could you please be so kind and fix your quote? Took me a while to find your text.
