[AMZ-US] SP40 KIT
14th July Code:
Code 1: NQMF-PFER6P-2B83AB
Code 2: NQRQ-GYG7TM-BW5DAM
Code 3: NQNC-DJN386-JFPUAP
Code 4: NQ3K-X3JPMZ-C6SYA9
Code 5: NQU2-KV3MDB-3E8GA9
[AMZ-US] SP40 KIT
14th July Code:
[AMZ-US] SP40 KIT
15th July Code:
Code 1: YBX6-HZDYPG-4GNNA3
Code 2: YBLY-9VMUDR-MRHTAD
Code 3: YBQH-UUL5TH-UPUGAS
Code 4: YBMH-2FL8ZK-M789AW
Code 5: YBZ4-K3ACAG-4ZEVA7
[AMZ-US] SP40 KIT
16th July Code:
Code 1: NQMA-USXM6G-ASZSAT
Code 2: NQLA-VJDUNT-VY7FA9
Code 3: NQVW-XHWVP8-7J93AE
Code 4: NQNZ-L937TG-A4QMAE
Code 5: NQVX-LL86R6-39N9AL
SP36 BLF Anduril kit
20th July Code:
Code 1: MLMZ-YZAB72-RESSAJ
Code 2: MLA6-NCW58R-YT46AM
Code 3: MLWH-UVE72Z-DNM4AK
21th July Code:
Code 1: MLNY-EPHEVK-Q9WAAZ
Code 2: MLLG-Z9TCVL-9K5YAP
Code 3: MLWS-2Z4H2C-GSMDA5
22th July Code:
Code 1: MLYD-H9LLVS-SQNCAF
Code 2: MLJR-HX2YAK-LXXSAL
Code 3: MLVC-PQQRAY-SMR5AK
Can any of these codes be applied to the the SP36S or do you have a different code for that? I am hoping to give one as a gift.
This code just work on the SP36 Anduril version.
And will make a sp36s code to you later. Thanks
23th July Code:
Code 1: ML57-5NNHV6-J289AD
Code 2: MLCW-VAFQLM-T5EDAB
Code 3: MLBJ-8KJUBZ-NPSCAP
7/23/2020 used ML57-5NNHV6-J289AD
Thanks!
Light ordered. Thanks Sofirn
24th July Code:
Code 1: MLNJ-TCBAJ6-T3XGAA
Code 2: ML6R-YUKD52-YF8HA9
Code 3: ML2R-K8V8H3-5S2NAA
SP31V2 kit code
26th July Code: [Please add the 10% coupon together with the discount code, and then you will get 40% off]
Code 1: XSU5-5JWBKU-RJWCAC
Code 2: XS6C-M39NBT-2ZPEAU
Code 3: XSZJ-5ZFAZ5-D8PVAY
Code 4: XSZ2-9MVZEH-XV5ZAY
Code 5: XS7P-YDE9N3-JMUZA3
SP31V2 kit code
27th July Code: [Please add the 10% coupon together with the discount code, and then you will get 40% off]
Code 1: HL6H-LQQFAF-Q32JAL
Code 2: HLVH-K8MPCD-B98YAE
Code 3: HLBU-VQ6P3X-8VX8AS
Code 4: HLQB-8Q85SQ-ZL29AJ
Code 5: HLT2-435PVR-TZ6HAD
I would like to give a thumbs up to the new Sofirn SD05 Diving flashlight. It is very durable. I tried an Efest 3700 mAh 30A high discharge 21700 battery. The power running at medium got hot (Summertime, 81 Fahrenheit on land). The battery tripped but the Sofirn SD05 driver did not skip a beat. With Imalent my experience was quite the opposite. The battery was fine but the flashlight (driver) died. With SOFIRN SD05 the battery tripped but the flashlight is shining as brightly as ever using another 21700 battery! Reliable flashlight! Underwater it will be even better as heat will be less. Sofirn SD05 = excellent diving flashlight for crab spotting.
I also like the Sofirn SP31 v2 tactical flashlight kit very much. I have used it for awhile now and it’s still shining as brightly as ever!
Pleased to hear that you are enjoy your SD05 flashlight.
SP31V2 kit code
29th July Code: [Please add the 10% coupon together with the discount code, and then you will get 40% off]
Code 1: HL74-Z6PQNB-LJZHAP
Code 2: HLWW-MLYRD5-NQFMAM
Code 3: HLVN-YF58UJ-ZFDPAU
Code 4: HLXJ-XBUSSC-NYXJAJ
Code 5: HLMC-829GUD-S44SAG
SP31V2 kit code
30th July Code: [Please add the 10% coupon together with the discount code, and then you will get 40% off]
Code 1: HLME-MKEDPF-VWY6A3
Code 2: HLRH-DT7A3J-R5W9AP
Code 3: HLL4-7K3AL3-J78TAV
Code 4: HLTE-GLTTFA-UKWXA3
Code 5: HL2F-5R54AC-RCWGAC
SP31V2 kit code
31th July Code: [Please add the 10% coupon together with the discount code, and then you will get 40% off]
Code 1: HL66-4XMSL6-BAT2AQ
Code 2: HL6M-UN8QXV-VXJ5A5
Code 3: HLJP-D8QGMA-A2Y9AD
Code 4: HLF8-V4XRAX-8QCUAH
Code 5: HLKH-PR8BGL-AESWAT
