That driver is designed specifically for the Boruit D10 (probably works with most of the varieties of that light too, like Sofirn/77Outdoors D25), which takes an 18650.
So far, Anduril works with several ATTiny MCUs, which we’ve made work with Li-Ion chemistries. Cell size doesn’t really matter at that point, just design a smaller driver to fit the host. There’s not a whole lot of reason Anduril can’t fit on a 10mm driver besides space, which would allow for 10440 and even 10180 lights to run Anduril.
This thread has some information about the quest for AA Anduril support. To my understanding, there’s a prototype driver design being tested currently.
Yes, but I’m still waiting on a good 14/15mm 12v boost driver.
All the triple optics I’m aware of have a much larger diameter than makes any sense for a 14500 light.
But triple is more efficient than single and with the Vapcell H10 or Shockli 1000mah cells, it will be able to make use of triple emitters no problem. But I’m hoping for a 14500 version of the Manker MC13
Triples and quads have been great these past few years, but I miss single-emitter lights designed to be as small as possible. They generally had the most practical beams and were the easiest to carry. Extra lumens are neat, but on something small I carry around all the time I don’t really need more than ~100 lm or so.
So for a 14500 light I’d be pretty happy with a really thin light with a single E21A and a 500 mA buck driver or linear driver. Even just a single 7135 chip and a MCU would suffice.
But I probably wouldn’t buy a 14500 triple. It’d be wide enough that I may as well just use an 18650 light instead… and floody enough that I’d need to use twice as much light to see what it’s pointing at.
This is why multiple emitters are used instead of one, to increase
efficiency at high currents.
Problem the head size of 14500 host for put a triple, Don’t know if there are lens/mcpcb smaller than 20mm
If you use this lens size and also need to increase head diameter,yes there is no reason for do that.
I just launch idea
Efficiency, as measured in lumens per Watt, is usually higher with more LEDs. Like, at a given power level it may produce 5% more lumens or 10% or even 50%… and the greatest gains happen at the highest power levels. At low power, there’s very little difference.
Efficiency, as measured in candelas per Watt, is usually higher with just one LED. That is, assuming the overall diameter of the host remains the same. Take the FW3A vs FW1A as an example. The single-emitter version is about 500% as efficient, illuminating its target about 5X as bright at the same power level.
So you’re both right… you’re just talking about different things.
In the case of a 14500 version of the FW3A or FW1A, the topic of efficiency boils down to this: At a given power level, would you rather have a ~10% increase in lumens or a ~500% increase in candelas?
Basically, do you want an extreme flooder at ~2 cd/lm or a balanced beam at ~10 cd/lm?
Great explain ToyKeeper thanks.
Anyway yes I’m interested on mini FW1A if will be relase with AA compatibily, High CRI very warm option,small size and price.
Also an Headlamp version with these specs and ramping ui would be great…
I’m pretty sure it throws farther than 92.5 millimeters.
(that’s the length of the light)
Anyway, the FW3A XP-L HI gets about 4.4 cd/lm, and the FW1A XP-L HI gets about 23 cd/lm. Roughly 5X as many candelas at the same power level.
However, the FW3A can make about 2.3 or 2.5 times as many lumens. So on turbo, the difference in candelas is a factor of 2 (ish) instead of a factor of 5. But it uses like three times as much power to get half as many candelas.
There’s no question that throwy lights are more efficient at producing a bright hotspot. That’s the whole point of a thrower.
For me though, it’s not about efficiency… it’s about having the right balance. And I think the optimal balance for a small EDC-style light is roughly 5 to 15 cd/lm. This provides a useful mix of flood and throw for common daily tasks.
A 14500 compact triple would end up with like… 2 cd/lm. And a single-emitter version would be closer to 10 or 12 cd/lm. So I’ll take the single-emitter version.
If it were the other way around though, like if we were using a really tiny LED which produced a ridiculous amount of throw, and the numbers were 10 cd/lm for a triple or 50 cd/lm for a single, I’d choose the triple. Because it hits the balance I’m looking for.
