I’m seriously impressed that Convoy is planning to try the SBT90.2. It’s a VERY EXPENSIVE emitter and Convoy lights are known to be real budget lights.
Simon, if you are planning to explore high end emitters, I recommend the Oslon CULNM1.TG Boost HL, which is the higher power version of the CSLNM1.TG or the CULPM1.TG Boost HX, which is the higher power version of the CSLPM1.TG.
Right now only Manker is using the CULNM1.TG because they were nearly unobtainable previously. Skylumen also mods lights using the CULPM1.TG. Would be sweet if Convoy can source these rare emitters.
Didn't Dale (DBCustom) build a beast ("Ham'r") with multiple FETs in joint circuitry for way more than 20,000lm using a whole bunch of LH351Ds below some carclos?
Anyway, 4x18A....geeez....that's 72A which equals in way over 250W! What host is able to sustain and dissipate so much heat? Please don't come with some active cooling by ventilation. Rotating, moving parts in a flashlight... :FACEPALM: It will probably take 4x Samsung 30T or 4x Molicel P42A in 4P configuration to get this amount of power without collapsing springs or batteries going nuclear. :-D
I did not mean to joke at all. The light you have linked to is for sure not consuming 4x 18A. It's just a light named "4x18A" but it's one and only XHP70.2 cannot drain more than approx. 18-22A from all 4 batteries. Anything beyond would burn this LED.
I should have read more carefully. Sorry for my misunderstanding. Reading “4x 18A” I was thinking, someone wanted to put 4 (four!) SBT90.2 into one single host.
Convoy M3 at 15-18 amps would be a nice and smaller host. Very heavy light to control some of that wattage. Even the M21C-U has good potential. I’m more into single cell lights.
