I’ve cycled many thousand miles with the trusted Hope R4 lights for many years. It was pretty costly when it was purchased and proven the money spent is worthy.
I’m with the OP. Expensive bike-only lights with built-in batteries are not for me.
My commute is just over 18 miles (29 km) each way. Being able to carry a spare battery is an important feature for me, especially in the winter.
I ride mostly on paved multi-use trail, so beam pattern isn’t much of a concern.
I really like a Convoy s2+ with biscotti on the handlebars, and a rear-facing red Jaxman E2L on the saddle tube. If my supply of good 18650s every gets low, I plan to replace those with a Convoy S21a or a Sofirn IF25a on the front. Not sure about the red tail light in 21700, though.
I have good mounts for my flashlights that haven’t fallen off in thousands of miles of riding. What sort of fiddling are you referring to? I just turn my lights on before I ride.
My commuter bike has a hub dynamo, and i replaced the very weak headlight that was on the bike when i bought it with a Busch + Muller IQ-X. IQ-X - Busch + Müller EN?
The IQ-X is approved for Germany and it does not blind oncoming traffic, but i also have a Convoy C8 XPL-HI on the handlebar, that is the “high beam”.
The rear light is from Busch + Muller and it also works on the hub dynamo LINE - Busch + Müller EN?
I use my BLF Q8 as my main bike light. I use a GoPro attachement with movable joint to have it pointed down in front of me, and ramped down to relatively low setting. So I can see the road, but to not blind anyone. When I go off the road and reach the forest, I point it almost straight ahead and put it on full blast. It termo regulates down and I leave it at that. I use the Q8 due to its capacity, and ability to go both very high and very low in light output.
That is interesting. I would like to see the dedicated light with such a pattern. Do they have an additional reflector like a car headlamp? Seems to me that even with the hot spot directed at the ground 700 lumen or so jus the spill on from a C8 would be blinding for oncoming traffic on a trail. Have not seen a light that would fix this with a beam pattern. Perhaps I am missing something?
That’s why elliptical TIRs are so in vogue. Basically no “hotspot + spill”, just a nice graduated hotspot, and the stripes toss the light left/right into an ellipse vs one big happy circle.
I don;t know really.
It doesn;t look to me like it is blinding cars. No one ever high-flashes me.
But it doesn;t have a sharp cutoff at the top either.
I guess I keep it pretty much pointed down at the road, maybe that makes it work.
The one I have is Thorfire, something with 2 leds and 2 reflectors, both pretty smooth.
To me it seems like a good throw/spill pattern for riding.
After being unimpressed with real-life usefulness of the FW3A, I put it on my bike and I like it a lot, mainly because of the floody beam, battery check feature and also the bike blinker. The small size and light weight are a bonus.
Cut-off might be still useful on less populated paths since it makes the beam wider without lighting up the sky resulting in less eye fatigue due to absence of constantly shaking narrow circular beam + easier to spot animals attempting to come out of the forest. Fenix bc35r and bc25r seems to have a wide enough uniform beam, just requires swapping out the emmiter for 3200k 90cri one if one has aging eyes which tend to block out the cool white light making everything dimmer.
Cut-off might be still useful on less populated paths since it makes the beam wider without lighting up the sky resulting in less eye fatigue due to absence of constantly shaking narrow circular searchlight beam + easier to spot animals attempting to come out of the forest. Fenix bc35r and bc25r seems to have a wide enough uniform beam, just requires swapping out the emmiter for 3200k 90cri one if one has aging eyes which tend to block out the cool white light making everything dimmer.
I have old one BC30 and I bought the new version 2 for friend. The wireless remote switch is the best upgrade of the BC30 but new version lack with LED choice. SST40 is cool white version and didn’t like them at all. In old version they used neutral XML-L2.
Yes I tried some time ago but on front leds when you remove aluminum piece there are little riverts on both side of light which hold LED mount to the body. You must drill them if you want to remove front led MCPCB (?). I didn’t do that because they also have thermal function to the light body. Also I didn’t wanted to brake my BC30.
Thanks, all, for this most interesting discussion. I agree that for many cyclists an EDC light will be fine. But I also sympathise with @wle:
Here in the UK I didn’t find it easy to buy a decent mount for a standard flashlight. Some of them involve Velcro, which is certainly fiddly on a dark night with cold hands. Another point is that not everyone has much room on their handlebars. My Magicshine Allty 2000 has a Garmin mount, which is very standard in the cycling world. It’s quick to attach, very secure, and goes on an out-the-front bracket that saves precious room on my tapered bars.
Decent buttons and a simple UI are good when you’re hammering down a hill and suddenly realise you need more light, or have to dip for an oncoming car. The Allty 2000’s UI is way too complicated and the low-profile button isn’t easy to use when wearing gloves. For day riding, I also think a flasher is great, which is not something I’d want easily accessible in an EDC light.
Excellent tips about the Lumintop B01 and Fenix BC30, with their car-friendly beam patterns. I knew Germany has a law about this, but as far as I know none of the brands you’d find in a UK bike shop offers a proper beam for road riding.
Maybe I have good eyes, but never has a bicycle or someone walking down the street with a flashlight ever blinded more than the cars going the opposite way.
