What did you mod today?
If it bothers you, you could sand down one side of the lens to make it frosted and that should eliminate the donut hole entirely.
Not sure if I got you right, the LED should survive the higher temperature.
I think I got you covered. :+1:
I ordered 20 of each value I picked. At digikey 10 was .15 cents so I just ordered 20 of each value. I could probably save some money buying one of those 172 value assorted resistor books from Ali.
You will like the ease of modding the Ti3 if your going to use the original mcpcb, if you go copper mcpcb then it will take a little more effort.
Went to just throw the stock emitter in my modded D10 for now. Screwed on the tailcap andā€¦ instant 100%. Whoops.
Started troubleshooting and found that LED- was shorting to ground. Driver being bypassed completely. Eventually found the culprit was sloppy soldering at the LED- contact on the driver. Re-did the LED- and LED+ at the driver. Next issue was the light was just completely dead. I wasnā€™t getting ground contact from driver/charger board to the body tube. Threw some solder blobs on the ground ring in a strategic spot and did another test-reassemble. All good now! The use of 22 gauge wire throughout, a probably crap-bin XM-L2, and rather long LED leads mean turbo isnā€™t anything special on this - but thatā€™s not what this lightā€™s about.
I love having on-board charging for an Anduril light thatā€™s also a nice compact headlamp. Iā€™m tempted to, at some point, order a D25S and another of these driversā€¦
Edit: forgot to add, it has a nice sub-lumen minimum output. Must be the 1x7135 channel.
Second edit: went to turn in for the night and the red switch LEDs were bright. I decided to find out if they were proper Anduril-controlled aux LEDs. Googled up the user manual. Put the light into lockout and suddenly the LEDs are blinking (off, low, off, low, high, repeat). Awesome!
2019 RRT-01 to Red
pic is a link
Good stuff Scallywag, glad you breathed new life into the Olight! That was one of the first lights I tried to mod, with my very limited knowledge at the time, and really could have chosen a better light to start with :blush:
Thanks for the tip NeutralFan. I actually wanted to keep the hotpost and a ā€œfrostedā€ lens will probably erase it.
I tried it below a pebbled TIR, but it loosed a lot in distance range. I would need a shorter reflector, eventually, to avoid the ā€œholeā€, but I donā€™t have any around that I can try. Next weekend I will try it outdoor and see how it looks. In case that artifact bothers me, I will probably follow you suggestion or add some DC-Fix!
Again, thank you :+1:
It couldā€™ve been worse - you couldā€™ve tried to start with a Zebralight!
Itā€™s a great light. I prefer Olightā€™s modern UI (or, idk, maybe it has changed - I like the UI on my S1), but only for minor quibbles - itā€™s not like this one has H-M-L mode order or something. They could have, like the Thrunite, offered a higher output on 14500, but I donā€™t find that super appropriate for a fully titanium host (and it will likely carry Eneloops anyway). Rather, I like that, as with my DQG Slim AA, the 14500 low modes are the same as the AA/NiMh. That ruined the Thrunite on 14500 entirely for me when I lost sub-lumen moonlight. And the emitter choice - but then, thatā€™s Olight anyway.
The only really rough bit for me was getting the driver out of the pill. I even contacted Olight to see if they had replacement parts available (no - although they were trying to get me to send it in for paid repair, which I did not want) so I knew if I mucked that up it was game over. There was a tiny bit of epoxy on about a third of the bottom edge of the driver, but it didnā€™t offer much resistance once I found a good way to pry the driver out - again, it was not much epoxy at all, and it probably didnā€™t stick very well to the aluminum pill.
As for the D10, some updates. With the stock XM-L2 and running in turbo for a minute here and there, the body wasnā€™t getting warm. It was also running with a 3500mAh protected cell (not sure on the exact cell, but probably LG MJ1), so itā€™s pulling less than 8A that the protection circuit is rated for. Iā€™m going to stick with lower-drain 3500mAh cells and not put something silly like Luxon V or SST40 in there, since thereā€™s no temp sensor near the LED.
Ok this whole D10 era predates me. Someone fill me in.
The whole inner battery holder piston moves and acts as the momentary switch?
People are modding them with Anduril cause of the minimal vintage tube look and feel but getting latest ramping firmwares?
What am I missing vs an FW#A flashlight?
I believe now he is talking about the Boruit D10 Headlamp and not the Nitecore D10, the one that is a piston drive.
Although there are other threads mentioning it, Iā€™ll link you to a mod by CRX of the Nitecore EX11 that is similar to the D10, but a 16340 light:
About the D10 with Anduril, hereā€™s Cereal_killer mod: What did you mod today? - #8285 by Cereal_killer
The piston + the moving ring on the pill make it act like momentary and also as e-switch.
I did not know how well the lead free reflow solder and lead reflow solder mix. I just burned up a XHP70.2 and that may have caused it.
Is there a way to tell the difference ?
I should probably specify Boruit D10 vs Nitecore D10. I donā€™t own a Nitecore D10 - though I do own a Nitecore EX11.2, which is directly related (and 16340/CR123 instead of AA/14500).
The Boruit D10 has an Anduril FET+1 driver currently made by Quadrupel.
That I know of, Cereal_Killer made an Anduril driver for the Nitecore D10, but the board is not public. AFAIK there is not a currently available driver for the adaption. Iā€™ve debated asking about sending my EX11.2 to gchart and seeing if he can puzzle it out, but I currently canā€™t even afford to ask about it :wink: being unemployed. An Anduril FET+1 (or similar) would be nice for this host. For me, the stock ramping is just far too slow, and I donā€™t trust the current driver with Li-Ion very much. And as long as Anduril has a separate channel for the single 7135, the minimum output is sub-lumen and good enough for me (evidenced on my FW3A and now my Boruit D10).
In my experience, a touch of good olā€™ 60/40 or 63/37 mixes in quite well and drastically improves the performance (melting point and eutecticity) of most of the RoHS-compliant solder Iā€™ve encountered.
However, given that LEDs can be in RoHS-compliant devices, I donā€™t think they should have an issue being reflowed with lead-free. And the solder mixture of lead-free and not- shouldnā€™t affect thermal properties enough to burn out your LED. Did it burn up on a long turbo run or very quickly after being powered? For XHP70.2 Iā€™d be more worried about the heat-sinking of the MCPCB, since they can happily consume 150+ Watts.
I havenā€™t tried DC-Fix, but Iā€™ve tried a pebbled acrylic lens and found the frosted glass lens is still better at allowing some throw. I have a pebbled acrylic lens installed on an S3 with a CREE XM-L2 LED. The frosted glass lens was not enough to smooth out the artifacts. Even with a pebbled acrylic lens, it still has a good hotspot and throw.
Outdoors you may not even noticed a donut hole. I do my evaluations against an indoor white wall, but I may be more of a perfectionist than others.
So, tonight I decided to give something a shot.
Last year I had gchart build me a mini smart tailcap, which I got in October. Today I finally tried to install it.
First, I had noticed shortly after I got it that the fit was an issue. The D25Cā€™s tailcap isā€¦ Well, at this point I hate it. The board kind of sits on there loose and rests on a tiny little lip in the body tube at the bottom of the threading. But up at the top where the tailcap board would go, thereā€™s a narrowing of the tailcapā€™s internal diameter. I hadnā€™t noticed this or given the diameter to gchart, so the tailcap board didnā€™t fit up there.
Today I carefully measured and found the difference was about .80mm, and I indeed had an average of about .40mm (barely, in a few spots) that I could file off. So away I went. And I finally got the fit working there.
Next, I went to attach the smart tailcap board, and melted the Omten 1288 just enough to stop working. Nice one, me. Itā€™s okay, I had a spare I grabbed off something. Got the board and the new switch on.
Next, whole stack was too thick. The old configuration had a thin metal washer between the switch boot and the top of the Omten. The new lit tailcap was in its place, but it was just too thick for how this D25C switch assembly is made. Even though I chose the .8mm thickness PCB. By comparison, the washer is 0.50mm - thinner than most of the components on the tailcap board, not just the board itself. I tried to use another, thinner tail switch PCB I had (to gain some space) but the fit wasnā€™t right for the shelf. And I ruined the second Omten 1288 I had. So, Iā€™m fresh out now.
Fortunately EagTac sells the full assembled switch on a board on their aliexpress store, so I donā€™t have to worry about melting the next one I put in to get the light functional again. I have to just accept at this point that unless I can find a perfectly sized lit tail more in the style of Convoyā€™s - where the LEDs are on the switch PCB itself - Iā€™m not going to get any lit tail in this D25C.
Cool thing, though: I got the ā€œbleeder resistorā€ right with some graphite (pencil lead) on the OTC.
What Scallywag said, they do mix. Not sure about long term effects. But: Thus far I have not reused any LEDs from RoHS-compliant lights.
Also, I canā€™t see what kind of solder is on my LEDs. Experienced users might, donā€™t know. Best would be to mark them somehow after an emitter swap. Just use an IR thermometer to see when solder melts on your heat plate.
:frowning:
Last night I modded this little utorch s1 mini. As it came it was pretty much worthless and saw zero use.
Iā€™ve been getting more and more into road biking, living out in the country the smallest ā€œblockā€ I can ride around is an 8 mile trip and Iā€™ve been increasing my ride distances more and more this summer so I converted it to a red light to replace the little plastic-button battery-store bought tail light I had been running. This way Iā€™m able to carry a spare battery on really long rides and actually get some use out of the S1 in the process! I also built a mount for it out of a electrical Conduit hold down band.
LED is a 660Nm XP-G2 on a heavily clearanced 16mm KD board. I also ordered a set of 7135 fet driver boards for it I found in oshpark since I read the stock driver didnā€™t like low vF ledā€™s but Iā€™ll try it out before even looking into building one of those. It ran all night and was still happy when I got up thismorning.
Hum, very interesting! I may need to try it. I only have frosted TIR, not frosted glass lenses. Obviously the TIR will reduce more the throw
I tried it outside yesterday at night and despite it was not in a picth black environment, I still noticed the hole. It bothers me a little bit, but I will try to reduce it somehow. This weekend I will test it on darker environments to see how it looks and will report.
BTW, before finishing the mod, experimented the S2 OP reflector: the hole was even more noticeable!
Thanks for your input :wink:
Hey, the tailcap board works GREAT. I just need to pick a different light for it. Also you didnā€™t do anything wrong - everything met the specs I provided, that light was just never going to work. I just have to accept that and pick a different light for it. My Jaxman E3 is already getting nervousā€¦
