[Update]Wurkkos dual LEDs 21700 Headlamp design Photos/UI update~
I never thought having it inside. It might be a good idea or maybe not as you contemplated.
My suggestion was to keep it outside, easier to remove and probably less costly.
This particular magnet ring fits perfectly around the rubber booth or metal switch. Like C8s, S2, S3 VG10s etc……
It’s easy to remove, just pry it out, in a second. Some people use a tiny bit of glue to keep it more stable around the switch that prevents it from accidentally coming out. I am sure people will come up with a little more sophisticated solution as well.
It sad the factory delayed the production, just start on CNC cutting ,will update as soon as it start assemble
The Skilhunt H03C headlamp uses the “XM-L Color” LED (single-LED with white/blue/red/green), but the white has only around 200+ max lumens, if I recall correctly.
I like the idea of a dual beam headlamp but this thing is big and heavy.
Couldn’t it be designed like an ordinary headlamp with the head part “streched” to acomodate two light sources? Imagine two H04 heads together on one tube.
SK H04 is some 45ish grams, so with longer head part the whole thing would be something like… 70ish grams?
Someone needs to TIG weld H04 and H04R heads together :smiley:
Or maybe I’m just dumb and rest of you know why something like that wouldn’t work.
That sounds interesting, will check it out.
Tried .still hard to minus the weight, only 10 gram less :open_mouth: :open_mouth: main use may better as a angle flashlight, and a headband will as a part of accessories in package, i did try on my head, If it is not used for a long time, it is acceptable
The mistake is to place charging circuit into host. It take precious space and complicates host design. USB port is a hole in host which effects IPX
And it was never known again about this flashlight.
He has to have it built, test it, revise it, etc. You don’t want him to just give you the first thing they turn out it takes a bit of time to iterate a good product. I’m super excited to have a company asking what we want and need in a light and allowing us to be a part of that process lets be patient with them as they take all these ideas into consideration and create something for us that can be mass produced. As Wurrkos grows I have high hopes for the enthusiast driven approach they are taking.
P.S. 21700 deep carry edc next please
Wurkkos HD20 is definitely coming soon. I’m currently working on the English/German manual, so I kindly ask you for a bit more patience.
I also suggested Wurkkos to take a (deep) red+white version of HD20 into consideration.
Wurkkos HD20 is probably being launched as of next week. Please stay tuned...
Exciting :+1:
This looks massive for a headlamp! :open_mouth:
I‘m pretty sure they will also offer a bundle version with battery again. But let’s wait for Wurkkos to confirm. I bought a 45W USB-C PD charger and a 100W USB-C (type C-C) cable today to be able to testing both type C-C charging and reverse charging of the HD20.
This is an excerpt from the manual, showing the UI of HD20.
RIP ramp mode
Looking forward to this release.
Just saw this. Interesting development do far
Good UI.Don’t think that would be good headlamp with such weight and dimmensions. But UI is quit well
Thanks for your feedback so far. I agree that HD20's weight might be a bit on the high side to some people. However, there's some potential here using it as a classic tool lamp on a belt, in one's pocket or - as I prefer to wear headlamps - around one's neck, shining in front of your feet while having both hands free.
Meanwhile, I agree with AEDe that - from a point of consistency - a single click from turbo mode should normally turn off the light instead of bringing you back to the previous standard mode. Due to the hidden strobe modes (triggered by consecutive doubleclicks) some compromises were necessary here. So, the original style was adopted, i.e. one click will return to the last used standard mode and one more click will eventually turn off the light.
I hope to keep on collaborating on the improvement of future UIs with Sofirn/Wurkkos, especially in terms of dual e-switch configurations, see my concept about Wurkkos WK30S. I hope they will soon introduce multiple firefly/moonlight modes as a separate sequence, lately introduced by Manker with their MC13 and E14 III.
Thank you Lux! any update on the release date?
