Awesome! Can I ask a huge favor? If the review is not ready for publishing before the 20th could you post a sneak preview of the runtime graphs for the high mode early? IDK about other people but for a small 18350 light like this, an efficient driver is the deciding factor for me.
If not then I’ll be keen to read your review on these lights when you post it. They look amazing and I haven’t found reviews on these lights online yet.
Not an example of poor management but a whole different category of budget. While the beforehand mentioned Zebralight flashlights target consumers with figuratively big pockets, Wurkkos's FC11 is a true budget flashlight for less than $30 including battery and some more accessories that Zebralight will not even supply with their lights for prices of $ 80 and more. So, it's like comparing apples and pears. If you want a flashlight with a fully regulated buck/boost driver, you will definitely need to pay more than $ 30.
Signed up for the pair. I already bought the E14 III. Shipped fast too. I want another and that little thrower looks nice. I got the Acebeam E10 and a Catapult V6 but, I’d find a good use for the thrower.
he says:
"with the long version you need to use a protected cell! An unprotected would be much too short! has not enough tension... well - it would work also.. (shakes the tight cell) ...hmmm... i feel its not optimal... (flashlight just works) but optimal is a protected!"
:D
€dit tested and found no downside from using a short, unprotected cell (30Q)
on hart tap it has a short disconnect, but the driver design allows to come back in same mode immedeately!!
Interesting. Some members on TLF reported that Acebeam‘s L17 had disconnects with too short 18650 cells, e.g. Samsung 30Q or Sanyo NCR18650GA. I’m curious if MC13 will also require longer batteries.
Naturally there is a balancing act when trying to accommodate protected and unprotected cells. If you go too much one way, you can risk crushing the longer cells. If you go too much the other way, unprotected cells can flop around. It is hard to be perfect for every cell.
In the product description in mankerlight site:
“3. Low battery indicator:
Voltage <3.2V, the brightness level downshifts to Moonlight.
Voltage = 2.9V, turn off.
(Ratio Error: ± 0.1V,while using different battery)”
Thanks for that information.Sounds like the flashlights probably do have low voltage protection.
It would be more reassuring to me if they clearly said that the flashlights have built-in low voltage protection using language that actually states "Low voltage protection" (instead of language that just states "Low battery indicator") because some flashlights behave the way they describe that do not have low voltage protection and downshift their brightness and eventually also turn off but continue to discharge the battery.
