@ contactcr
Thanks again for your input on the modding process
About the centering ring, that also happens with me on the i3, the “reflector” (IDK how its is called, sorry) doesn’t screw all the way down :zipper_mouth_face: I didn’t have capton, I used electrical tape, even if nor ideal.
On the mod, did you took the retaining ring of the driver out? It seems that it can be taken out of the pill throught those small holes in the side. I’d like to “maintain” the integrity of the original driver, it can be worth to make another mod
Normally I don’r solder any temp sensor wire to the led MCPCB Am I doing it wrong? :partying_face:
Or does it have to do with the type of driver you have?
I’ll put a L4P driver as well, but normally I don’t add those special temp things (I don’t actually know how to work with that ), hence my question.
Quite an improvement since the original measurements. A W1 would probably get some more intensity, but the W2 also seems to project the light far away
Well done
And BTW, you did a pretty clean job in the mod, I am very messy with this stuff :person_facepalming:
I may need to start thinking about a new spring for the spring, maybe the original is too thin afterall :weary:
@ luminarium iaculator
Thanks for your words! And I hope you are enjoying your light as well.
BTW, did you see the YAGE zoomie light that is pretty similar (although bigger) than this light on AliExpress? It is sold, the complete light for around 7€. It probably has aluminium pill and acrylic lens, and despite being bigger, it still seems a compact zoomie at a nice price
