I got my host from Chicago X in the meantime and just to let y'all know, the flat gray is really nice and IMO looks much better that the black DRY finish.
I did it this way because I had asked a member here, DrJones, about it and he stated that cutting the one leg was the easiest way to go. If it isn't, then I can do different. I do not know the benefits or concequences of any of it. I can understand + and - and electricity runs thru it, but after that I might as well be listening to someone talking about quantum physics for all I know. I would not think the EPROM has to be there at all, but I certainly do not want to try to remove it, unless I cut all the legs. I'm certain that I'm not going to attempt to desolder it.
The light is done! I can certainly say that this is probably the best job I have done so far, on soldering drivers and emitters. It's much easier when it's all laid out where I can put both arms on the table, to steady myself.
This is definitely the brightest thing I have ever seen. The U2 emitters are cool white and I really like that for Outside lighting. I prefer neutral to warm indoors, but Cool white seems better for outdoors (to me).
I am putting this up for sale now. I don't think it will sell. Unfortunately, it's going to be too high priced for a budget light. Between the host, 3 U2 leds, 3 driver boards and 3- 4/3AF NiMHs, it's going to have to sell for aroung a "hunnerd" bucks and I think that's out of the ballpark, but I cannot afford to take the hit unless I want to stop modding for a couple months to recoup the loss. Oh well, life's what it is. Stick with the bare bones hosts and give up trying to compete with Chinese wholesalers that sell stuff like this for less than half the price...
I'm good at it-used to work in defense electronics-(you think flashlights are small?!) but I'm suffering the same fate; lousy vision and the shakes sometimes. Right after a yoga class, when I'm all warm and relaxed, is a good time to solder.
Hi OL. Just saw this again. You certainly did good on soldering those boards up. I recently managed to stack 3 extra 7135 chips onto an 8 pce 7135 board for the first time. I felt like a winner after I hooked it up and it worked. Turns out a bit of locktite helps a lot.
And that was done merely days after I cr**ped a whole driver board up. Still dont really know how I did it but it would consistently be inconsistent when changing modes. It even invented some modes I've never heard about. But that is where I had the extra chips from.
Just out of curiosity - what runtime do you expect to get/are you getting with these here 3/4 doohickey something or other batteries? I havent ever seen something like that before. And in what charger do you recharge them?? They dont fit any charger that I have (with that voltage anyway).
Sorry about all the questions OL but you make interesting lights that raise interesting questions :-) Hope you dont mind.
4/3AF NiMH Used more for packs, or for industrial. 1.2v 4500ma but a high discharge rating.
I would think anyone with a Hobby Charger, would be able to charge them right in the holder. 3.6v that way, or as singles. I use a "modified" "D" cell charger. They are just a tad longer than "D" NiMHS.
Run time?? I haven't got a clue, but I would expect less than 15-20 minutes on high and much longer on medium or low. Low is VERY LOW, so it might run for days on low.
What a work of art. Truly impressive. You've inspired me to redo the 3xAA battery holder on my Cyclone C88. May I ask what thickness copper plating you used?
Regarding your Brinyte, could someone use 3 18650s or would that more properly be used with another meaning of the word "torch"?
The battery holder originally used three 18650 batteries in parallel. 4/3AF is the NiMH equivalent of 18650. The holder is now in series. I changed it from parallel to series.
As far as the copper plate, I believe it was 0.008" or what, about 32 gauge copper. 0.008" or 0.010" is fine. (30 gauge).
EDIT:
Here's what I can tell you about making your own. Remove the original plates from the holder, flaten them down and use them as templates. Just be sure to mark them somehow, before you take them out, so you know which one is which.
I just use a pencil to mark the outline on the copper. I cut the copper with a good pair of scissors. It's much easier to rough cut the piece out, leaving about 1/4" all the way round, then do the final cutting after. It keeps from having the copper get deformed so much. Once you cut them out, flatten them by putting them on a flat surface, cover them with a board or other flat object and hit the board with a rubber mallet. It will flatten the copper right out.
If you want to make the cups for the positive terminals, heat the copper till it turns color and let it cool back down. (heat treating softens the copper). Then use a small socket (the diameter of the cup you want, turn the piece upside down on a piece of soft wood, place the socket on the piece and hit with a hammer (tap it), till you get a cup. You can then turn it back over and use the next size socket, to work the cup into shape, lightly tapping or pushing. Just remember the copper is very soft after it's been heated, so it doesn't take much to shape it.
For soldering the springs on, pre solder a spot on the copper first, then pre solder the end of the spring, place it on the copper and just heat it. It should all go together much easier that way.
I ended up going back and flattening the cups out and just using solder on the positive posts, because of these flat top batteries. It worked better for the flat top.
Thanks for all the comments. They are much appreciated. I'm glad y'all like it. I'm glad it raises questions and makes people think of trying it themselves.
Wow! Thanks so much for your detailed comments Old-Lumens. Now you've got me motivated. Give me a week or two to order the parts, mangle the first one & try again. Then I'll show you what I've got.
That's awesome. I know that in the future I will also support the modifyers or local sellers instead of buying a foreign light.
I would love to learn how to do this. Is there a learning resource on the site that teaches about drivers, wiring, etc? I saw some threads that detailed mods, but didn't see a general learning thread.
If that is considered a hijack, please just ignore me.
No there isn't a general learning thread. All I know to tell you is to start reading all of the threads in the Modding Forum. Then ask specific questions of people. Usually you will get an answer that way. Look at people's sigs on the bottom of their posts too. Sometimes they link to more information.
