I put a new UV emitter in an SC31b. Bezel is glued but with a strap wrench and some elbow grease it can be removed. Don’t know about the SC31 Pro specifically but I bet its glued. However my guess is also that the SST40 looks fine.
As far as I can see this is the least expensive and smallest Anduril light out there, at least unmodded. You should be able to put a short tube and magnetic tail cap on it if you want. May have to get one.
Actually, a couple pictures clearly show a Micro-USB port and Micro-USB cable. However, others are definitely USB-C. Weird.
Compare top-left and bottom-right:
I don’t think that’s an easy swap as SST40 uses a 5050 footprint while SST20 uses a 3535 footprint. You may need a different gasket to physically fit in the smaller LED.
I ordered the 6.5k version a few weeks ago from sofirnlight.com the day I saw it uploaded. I just now ordered the 5k version from Sofirn AE and paid the TOTAL BS FAKE TAX!
but the coupon was for more than the tax so I begrudgingly pushed the order button
I really dig the idea of an EDC with Anduril onboard. My IF25a’s (I have both the 4k and 6.5k) have been in the pocket lately and they are great too- just a BIT hot at times
Just a note… my IF25a in the 6.5k version is closer to 5.8k and I REALLY like it outdoors where it can throw well for a little “pocket rocket”. But it’s definitely not 6.5k and I’m all about mistakes happening in my favor.
Quoted info from McCatFace’s post above :
There’s a brief video about it on YouTube already: https://youtu.be/qXecbBQsbtQ
. I’ve watched that video and i think that SST40 6.5k is a little too cold to me. Then again, CT is kinda subjective right? Different person has different taste/preference .
Thanks for the info Jackie. It’s really a good news for people that prefer warmer tint.
Btw, is it still possible to change my order? I’ve ordered the 6500K version, right before the 5000K version is available.
I do really prefer the warmer CT.
I have read your thread about Sofirn IF25A. I really like your review/overview/observation . It’s like a semi-long-term review with details of actual usage of the flashlight.
I’d like to hear/read your opinion on SC31 Pro both the 6500k and the 5000k later when you receive them and use them.
I’m very glad too that Sofirn producing more Flashlights with USB-C charging. Hopefully other manufacturers catch up with that.
I’ve been using convoy s2+ for about three years.
Then i bought convoy BD06, it has built-in charger (with little adapter attached to its side switch, and micro USB cable connected to that adapter for charging), I’m very happy not needing external charger to charge it, it’s very practical.
I think Sofirn SC31 PRO with USB-C port is even better, charge directly no need any adapter.
And I also want to try Anduril UI, from what I’ve read it’s a pretty amazing UI .
I’m glad to see they finally made a good change in the SC31 UI. I would buy one if they could now just shorten the body a little; something like an 18650 version of the IF25.
Smooth reflector and it is also shallower. I would describe the beam as almost identical to the SST40 version of the Convoy S2+.
As you probably saw in the album I was able to fit a TIR optic.
