These are the same values I measured. I swapped a 120ohm resistor on the green channel. It’s better but still too bright. After my resistors arrive, I will be installing some lower value resistors on the blue/red channels and slightly higher value on green.
Soldering the aux pads was definitely challenging. I used 30awg stranded wire. I feel like this would’ve been slightly easier with solid core wire.
Does that even help much? Those values just set PWM on the FET, they don’t magically lower the maximum current. So while the LEDs don’t get so bright that it’s obvious that they’re overdriven, they are still overdriven half of the time. I’m not exactly sure how this in turn affects LED life expectancy.
My understanding may be off here, because I really don’t get how limiting the FET should save the LEDs.
Lets move on from 219B. The prototype used it and people have been building them for years.
Stick with 3500mAh battery (like was already mentioned above) and assuming heat path and reflow are good, enjoy your CRI. If you think someone will stick their brand new uber vape batteries charged to 4.25V in your light you can ask for $9 LED deposit when you lend it out.
The 50% PWM firmware is just a hack and probably protects edge cases. The stock driver really had no other way besides disabling FET so people asked and that’s pretty much all you can do.
Yep… :+1: I have to agree… Lexel sent me a boat load of different micro resistors for these or his boards, I might mess around with the last driver, lowering the green and maybe the red a tiny bit more? Winter is coming…
Another option with the provided resistors would be to use the 330Ω on the green, the 100Ω on the red and just solder bridge the blue. Would that fry the blue?
I'm glad some people have received their boards! Unfortunately I personally haven't yet received mine yet, though they are in the mail and I should receive them sometime today hopefully.. I see that there has been a good amount of feedback so far so here are my comments.
Yes the system should work with red LEDs. However, you should make sure that FET is disabled; this can be easily done by changing the config files (e.g. change the ramping tables) and reflashing the firmware so that the FET is never used. The system will run in buck-mode for the entire range if red LEDs are used.
Thanks for the detailed feedback gokalpm. I'm glad you were able to get it working well in the end.
- I did not design the PCB with cutout because newer versions of the FW3x flashlights no longer have the notch, so I was told by Neal to make a round PCB. Filing would work to fit the older ones.
- The RGB aux board was designed for the Lumintop MCPCB not the Noctigon one
- The aux LED board should sit flush on top of the MCPCB. The Lume1 datasheet has an assembly section on how I put things together, and things to take note of as well.
That is a very clean build, thanks for sharing!
That's unfortunate to hear.. :( If you scroll back in this thread a while back when I got the first proto samples from Neal (the green PCBs), I found the resistors chosen to be non-ideal and made the Aux LEDs far too bright, and specifically requested them to be changed. I think Lumintop probably wanted really bright AUX lights, but that was not what I think they should be because I prefer the AUX LEDs to be very dim.
Personally, my recommended resistor values are:
1.8k for Red and Blue
5.6k for Green
These values allow for a good change in brightness when using the 'dim' AUX settings in Anduril as well (especially the breathing rainbow mode which I use most often), and they work really well in the nighttime, but will not be very visible in the daytime. These values are listed in the datasheet on Github too.
LED intensity is controlled by the resistors, so swapping wires from driver to aux board will not change the brightness, but will change the ordering instead.
No please do not use a solder bridge! I'll need to ask Neal why Lumintop didn't change the resistors to what I specified.
When I designed this board, it was immediately after I designed the Lume1 board, which I assemble and solder by hand. The actual driver board has smaller components so the LED pads seem easy in comparison, but you are right that normally this would be a challenging job because they're tightly spaced. [Update: it's done! https://oshpark.com/shared_projects/mtHUb4gp]
I quite like the bright aux that can be seen during the day. For night time, he dim setting is dim enough. I wish it was balanced though… I believe even with the swapping around of the resistors, the green is still brighter and the blue dimmer than the red. I think I may try 75Ω for the blue (since no resistor at all is a no go), 160Ω for the red and 330Ω for the green. I have ordered some 0402 resistors to try.
