ACEBEAM E10 LED Flashlight Released
40 posts / 0 new
Gatzetec
Gatzetec's picture
Last seen: 1 month 1 week ago
Acebeam E10 very small Light but with extreme range.
Three light colors white, green or red available.
https://www.gatzetec.de/Taschenlampen/Acebeam/E10.html
Regards Thorsten
www.Gatzetec.de
www.gatzetec.de
www.imalent.de
flashlights for friends
jasontheguitarist
Last seen: 2 days 23 hours ago
There should totally be a 26650 tube for this. It seems like such an obvious thing. That would allow using common batteries (18650s too with an adapter).
0oklight
0oklight's picture
Last seen: 5 hours 45 min ago
Having read this, led to just a minute of exploration..
Nightwatch IRA legos fine if that’s a help to you Smile
This is an Osram W1, it’s not like it’s suckin’ diesel.
2000mAh with this emitter would probably equate to 3000 – 4000mAh with any other emitter that had this throw.
Acebeam would have considered this is in the design of producing one of the furthest throwing/size lights short of commissioning Vinh.
IMHO they were probably thinking about pushing the edge of flashlight design over battery availability.
But you have a point, in the UK I had to order (on the internet) from Europe to get a handful of decent 26350s.
lite624
Does this light fits unprotected 26350 battery? Notice that the default battery is using 26350 with micro usb port, which the battery length might be longer than average cell.
toddcshoe
toddcshoe's picture
Last seen: 2 hours 34 min ago
I have an unprotected 26350 and it works just fine. I forget which light I got it with. SC26 maybe. Not sure but, it seems to work just fine.
"Everywhere I go, there I am"
SKV89
Last seen: 5 hours 33 min ago
The E10 works with the SC26 tube but you might want to get a thinner o-ring to make it slide on easier. The Eagle Eye X7R tube also fits perfectly but you might want a thicker o-ring to make it water tight. The Thrunite TC20 tube also fit but the spring is so long in the Thrunite, I’m afraid of crushing the springs.
cleo_stary
cleo_stary's picture
Last seen: 15 hours 11 min ago
I like this chubby little light…
SKV89
Output measured at 2 seconds from turn on using Texas Ace Lumen Tube calibrated with Maukka lights. Color measured using Sekonic C-800-U.
Acebeam E10 Turbo 562 lumens 7088K -0.0068 DUV 65.9 CRI Blue light relative amplitude 1.00 -15.0 R9 39.9 R12 56 Rf 99 Rg included battery
Acebeam E10 High 222 lumens 6695K -0.0031 DUV 65.1 CRI Blue light relative amplitude 1.00 -26.0 R9 37.9 R12 57 Rf 98 Rg included battery
Acebeam E10 Mid 103 lumens 6510K -0.0007 DUV 65.1 CRI Blue light relative amplitude 1.00 -31.1 R9 37.1 R12 58 Rf 97 Rg included battery
Acebeam E10 Low 12 lumens 6089K 0.0030 DUV 65.6 CRI Blue light relative amplitude 1.00 -37.5 R9 35.5 R12 61 Rf 96 Rg included battery
Acebeam E10 Moonlight 0 lumens 5534K 0.0034 DUV 67.1 CRI Blue light relative amplitude 1.00 -31.0 R9 36.2 R12 63 Rf 97 Rg included battery
It uses the same optic as the Acebeam L17. I like how with this optic, the spill gets dispersed evenly so the hotspot stands out more than with a reflector light.
The E10 works with the SC26 26650 tube but you might want to get a thinner o-ring to make it slide on easier. The Eagle Eye X7R tube also fits perfectly but you might want a thicker o-ring to make it water tight. The Thrunite TC20 tube fit but the spring is so long in the Thrunite, I'm afraid of crushing the springs. The Amutorch JM70 tube fits perfectly.
JaredM
JaredM's picture
Last seen: 1 hour 29 min ago
The ~98Rg explains why I find this emitter so bearable considering it’s 7000k turbo CCT. Thanks SKV
