[RD tech] RD6006 updated version RD6012 60V/12A NEW power supply released
RD6012 customer review
Delivered in 11 days, excellent. The product is well packaged. The assembly of the device is of high quality. It fits the description. I recommend!
www.aliexpress.com/item/4001053200176.html
The product is very beautiful. I highly recommend it. In fine works I think better research and get the 6006 model
It came, in appearance, all fits the standard. It seems to work fine too
(by the way, there will be promotion from 8.24 to 8.28, if you have something in your wishlist, you can check their price now)
RD6012 customer review(get 12 off for complete pack now until 8-28)
As always, the quality of the converter is quite high. Everything arrived without damage. The efficiency of the device reaches 98%. At a load of 650W, the heating of the components is negligible 60℃
everything is good, fast, tracked, the packaging is decent
Thank! Express delivery in hand. Great packaging. For information, the consumption of electricity at idle is about 10 watts (In the photo in the on - 10.9W, off - 9.8W of the converter). Recommend.
Hi.
Somebody asked if you plan to make a power load but you didn’t say anything !
where ? we have a plan , but it will be a long time
I already have some of your power suppply.
But I was wondering about electronic programmable power load, not USB tester.
edit : sorry I made confusion from your signature as an answer !
:smiley:
thank you so much for your long time support
I know the electronic programmable power load, not usb load, we have plan for this , it should be after this year
Hi RD Tech
I just bought the new RD6012W and the wifi does not work with OnePlus 5T or iPhone 11 Pro max.
However, its does work with old Samsung A3(2017) phone.
I have a BT SmartHub router with both 2.4Ghz and 5Ghz radio on. And yes I made sure the phones where connected to the 2.4Ghz network
when trying to connect.
Is it anything to do with 11ac wifi band? Can anyone help?
Thanks
please contact email 1749808860@qq.com , i will help you
RD6012 feedback
Everything works fine. I strongly advise! A power supply from a laptop or 12v - 10a can easily fit into a small case, but you need to look for a suitable form factor.
I have a OnePlus 5T phone with Android 9 and I cannot connect via Wifi and RDPower app.
However I did manage to connect with old Samsung A3(2017)
Hi everyone. Here is the link to a video of my problem
https://drive.google.com/file/d/1put5ecMHqB5ITJFsf-yrmzDRbaN87mVb/view?usp=sharing
Any help will be greatly appreciated,
Shaz
I have replyed you at email , if your Samsung A3 phone can work , our products and your operation should be not problem
so now the problem is your one plus phone phone and network problem
now use second phone hot spot as router to test again , if it can connect , it should be your network problem , please close your 5G to check
RD6012W feedback
It's all right. There are few screws left after assembly. Well packed.(that is backup screws:D)
Everything is super. Thanks to the seller. The case was printed on a 3D printer
RD6012: www.aliexpress.com/item/4001053200176.html
new RD6018: www.aliexpress.com/item/1005001488070904.html
Very good source, exceeded my expectations. Excellent precision. It arrived around 20 working days here in Brazil.
Today I receive the item, everything is just perfect! Paking is best, everything is OK. Thanks
Everything is correct and everything worked very well.
