What's a good option for under 150?
56 posts / 0 new
Banksy
Last seen: 1 day 18 hours ago
So my Bolder LC90 got stolen a few weeks ago.
I figured this would be a great chance to up grade.
I’d ideally like something a little less bulky however not something super tiny
I dont know much about flashlights, but I’d like something that can put out 1000+ lumens with good throw with a battery life that is very good
I have a ton of 18650s laying around so ideally, that’d be the battery type.
I’d prefer the button to be at the rear of the device but its really not a big deal.
150 would be the max I’d like to spend
I don’t mind spending that much as long as it’s merited.
Anyways thanks for taking the time to check out my post
Wrathbringer27
Wrathbringer27's picture
Last seen: 18 hours 10 min ago
Look for a C8+ by convoy
Words can be broken,
so can bones.
Andrew_Debbie
Last seen: 10 min 34 sec ago
Under $150us and 18650 ? Hmm.
I have a few suggestions.
Manker MK36 12,000 lm. Wall of light. If anything it is too bright on turbo. Very well made, solid construction. 3× 18650 lighter, brighter and more compact than a BLF Q8 or other 4 cell “soda can” lights.
Simpler UI with 4 brightness levels + turbo. Easy to use, but I would have prefered something more flexible.
Emisar D18 I don’t have one but worth a look. Brigher than the MK36 and it runs ToyKeeper’s Anduril firmware.
Emisar D4V2
I have a D4S, which is 26650. My D4S is the light I use every day.
MascaratumB
MascaratumB's picture
Last seen: 3 min 20 sec ago
Welcome to BLF Wink
I would also say to take a look at Amutorch flashlights.
With that budget you can get yourself some nice and reliable flashlights from different brands ! Thumbs Up
[REVIEWS] ACEBEAM: H20 / TK16 // AMUTORCH: S3 / S3 vs 219c / AM30 / AX1 / VG10 // BLITZWOLF: BW-ET1 // BRINYTE: T28 / PT18pro / PT28 // DQG: AA Slim Ti // FIREFLIES: ROT66 GEN II // HC-LIGHTS: SS AAA // KLARUS: XT1C // LIVARNOLUX: 314791 // LUMINTOP: Tool AA V2.0 + Tool 25 // NITEFOX: UT20 / ES10K / K3 // ODEPRO: KL52 / B108 // OLIGHT: M2R Warrior // ON THE ROAD: M1 / i3 / M3 Pro / 311 / Z821 / i5 // ROVYVON: A2 + A5R / E300S / A8 / A23 / E200u // SKILHUNT: M150 / M200 // SOFIRN: SF14 + SP10A / SP32A / SP10B // WUBEN: TO10R / E05 / T70 / E10 / TO50R / E19 / E12R // XTAR: PB2 Charger // Mods: 1 / 2 // TIR: 1 / 2 // Others: Biscotti 3 + 1*7135 / Triple TIR w/ XP-G2 /// My Collection /// My Review's Blog (PT) /// OL Contest 2019 /// GIVEAWAY: 1 / 2
Andrew_Debbie
To give you an idea of size…
Left to right:
Fireflies PL47 (first run), Emisar D4S, Manker MK36, BLF Q8
ggf31416
Last seen: 6 hours 12 min ago
Do you need integrated charging?
Banksy
I’d say I don’t need integrated charging
I have a 18650 charger and I prefer to do it that way.
I’d prefer something not super thick..wait let me rephrase that.
Thicc
Banksy
Ideally I’d like something that doesn’t have a angle on the head. Dunno what you’d call that. But the one on the far left isn’t going to work for my needs
How thick are the other three?
Banksy
MascaratumB wrote:
Welcome to BLF Wink
What’d you look at in the higher end of that price range?
Andrew_Debbie
Angled head Smile The light is a Fireflies PL47 from the first run. It uses a 21700 battery.
The other 3 from left to right.
Emisar D4S — Not suggested because it uses a 26650 cell 39mm diameter at the head and 32mm dia at the body.
Manker MK36 is 53mm at the head. Body is about 45mm.
BLF Q8 is 59mm head and 50mm body.
Andrew_Debbie
Looking for a compact, bright, high quality 18650 light? You should look at an Emisar D4V2.
It uses a single 18650 cell and is about 29mm at the head and 24mm body. I don’t have one but you can search here for reviews.
jon_slider
jon_slider's picture
Last seen: 14 min 19 sec ago
Tumbleweed48
Last seen: 2 hours 14 min ago
I know it has a side button, but I have to mention the Skilhunt M200. It has everything I’ve ever needed – direct access to moonlite, direct access to turbo, very simple electronic lockout, battery self-check every time you turn it on, locator led (if you choose), very good tint in the ‘neutral’ version, magnetic tailcap, magnetic charging, normal (not proprietary) batteries, well balanced beam profile with both decent throw and flood….I simply can’t find any weaknesses.
I have a bunch of ‘brand name’ lights, 30 or 40 I suspect (I’m scared to count them, and even more scared for my wife to count them!) but the Skilhunt M200s are my favourites of the lot. For the past six months everything else has gathered dust. And yes, I bought and paid for both of them; they’re not freebie samples.
Andrew_Debbie
jon_slider wrote:
rear button, over 1000 lumens, uses 18650
if you want to spend more, you can choose fancy metals for example Titanium
Debbie has a copper FW3A. Beautiful. The tailswitch requires an unusual amount of force but maybe hers is faulty.
azj
Last seen: 4 days 16 hours ago
Cant go wrong with an Emisar D4S or D4V2.
See these threads:
http://budgetlightforum.com/node/61509
http://budgetlightforum.com/node/72667
Both have lots of other options for body colors, aux lights, magnetic tail, etc..
edit: if you don’t run it on high/max, you’ll get your battery life, and you won’t heat up the place Smile
Geuzzz
Geuzzz's picture
Last seen: 1 hour 53 min ago
Op asks something with good throw. I would not recommend a D4v2 in that case.
NOCTIGON KR1 seems to fit much better.
jon_slider
Andrew_Debbie wrote:
copper FW3C. Beautiful.
so tempting
especially the shorty:
if the OP wants more throw, consider the single LED FW1A
Firelight2
Firelight2's picture
Last seen: 45 min 38 sec ago
Zebralight SC600w IV Hi
Andrew_Debbie
Missed that somehow. The Manker MK36 is a wall of light flood. That is the opposite of what the OP is looking for.
peg matite
peg matite's picture
Last seen: 19 hours 19 min ago
I agree. If OP is willing to spend that kind of money on a single 18650, a ZL would be a solid choice.
Geuzzz
Geuzzz's picture
I agree also, great option.
azj
Ack, ok. I’d have to second the Convoy C8 then, or maybe a BLF Q8 (or the Sofirn Q8 flavor), if you’re ok with “soda can” lights…
Majoroverkill
Majoroverkill's picture
Last seen: 6 hours 51 min ago
Under 150? Wow, there are so many torches to choose from it would depend on your style needs and wants. For that price you could look at the nicer looking lights that Jetbeam, Acebeam, Emisar, Olight and Fenix have to offer. Single emitter multi emitter, for 150 you have some great choices Big Smile Let use know what you decide on Thumbs Up
Doug S.
caramba
caramba's picture
Last seen: 3 days 9 hours ago
Finding Banksy for 150? Just kidding Wink
L90 looks nice. I wonder if something like VG-10 or tripple C8 would work, maybe C8F?
I dont have one, but Convoy M21B is something new?
Banksy
I like the looks of these.
However what I care about also is putting out a lot of light at a steady pace. Ideally 900+ lumens for a minimum of 1.5 hrs.
The VG 10 and C8 look wise are what I prefer however as long as it’s not a “soda can” I really have no preference.
If I had to say what I want looks wise the tactical would probably be it. Or tacticool as I used to call it. I carry a lot of knives. Generally microtechs so I’d like to see something match that kinda theme
There have been a lot of great suggestions on here and I’m still sorting through them.
Banksy
I’ll look into this
What are their best offerings?
lukehale
Last seen: 11 hours 20 min ago
If the budget is under $150, you could get something as nice as the Zebralight SC700d (or the floody version, but personally I would just use some DC-Fix or similar on the regular one). Those are only $119. I don’t think you are going to get a more efficient, reliable, versatile light, in that price range. The extra $30 could get you a couple of Samsung 50E batteries (5000 mAh) and a charger.
It will easily sustain 900 lumens (more with minimal cooling/holding in hand) for over 2 hours.
Quadrupel
Quadrupel's picture
Last seen: 47 min 36 sec ago
If you need 900 lumen for hours, you need BIG flashlight for heat dissipation and BIG battery min. 3×18650 for more power and boost or buck circuit driver for efficiency.
Banksy
I’m starting to notice that
I’m just really confused that my Bolder could put out 900 and some of these higher end offerings can only do like 750 for 1.5 hrs.
Is that because they have more throw?
I mean brightness wise all I know to go by is lumens what are some things I should be looking for?
Maybe that’d help me sort though these without just focusing on that one factor
Quadrupel
Quadrupel's picture
You believe in everything whats written on Chinese package ? ;))
Banksy
Well said.
