What is the difference between culpm1 and cslpm1?
Footprint c(u,s)lpm1
S 3030 footprint (max 6A?)
U 4040 footprint (more current 8A)
Led Size csl(p,n)m1
N 1 mm2
P 2 mm2
Colour Last two numbers cslpm1.(tg, fy, 23, f1, 13, 14)
TG 6000K
FY Yellow
23 Red
F1 Pure Green
13 True Green
14 Blue
Thanks RapidLux.
Will be any difference in lumens between culpm1 and cslpm1 at 3A current?
Not appreciably. The main advantage (still theoretical right now as it hasn’t been tested AFIK) is a higher peak current before its thermally bottlenecked. In other words, other than binning differences, CULPM1 will be about the same as CSLPM1 until current exceeds ~5-6A. And in a flashlight with other thermal limitations, maybe less of a difference will be seen. TBD with time
Whoops, just not used to typing out the model number of the 4040 version now that they’re available!
Hello Simon,
Can you get Osram KY CSLNM1.FY (yellow) emitters?
I would be very interested in a thrower flashlight fitted with that particular emitter, if you can source them.
Probably I would take a Convoy M21A, but if you can fit it into a Convoy L21A, that would be even better.
[Deleted]
It is a buck constant current drive,
Simon Mao: BLF-L: BurningPlayd0h:Anyone have a rough idea what kind of cd we can expect from the S21B with CSLPM1?
Is S21B also available with CSLPM1? I can only see it with CULPM1 :
I can create a temporary link according to your needs,
Thanks Simon. I think I’ll wait for the new upgraded version of M3.
btw, what is the name of this new M3? Is it M3A? or M3C-U ?
Beside that, I’m still waiting for my SST40 S2+ , I’ll be checking it first and see how much I’ll like the 5000K SST40.
Maybe M3-C, C means “type-c”.
Hello Simon,
I will try to order,
It would be nice to see M31C, 21700 size
Hi cri throwers
What centering ring did you use?
i’m ready to launch a M21C-U with type-c port
Stock, supplied with flashlight
Would you reprogramm ramping UI to be faster from MID to HIGH and a little bit slower from LOW to MID?
It’s hard to adjust low/mid output correctly and over mid it looks like raming is not moving, until i see double blink as max value.
S21B CULPM1 at 9A? Let’s do this.
Hi cri throwers
what led is?
