【convoy】H4 and B35AM options are updated
It would be nice to see M31C, 21700 size
Hi cri throwers
What centering ring did you use?
i’m ready to launch a M21C-U with type-c port
Probably this one.
Stock, supplied with flashlight
Would you reprogramm ramping UI to be faster from MID to HIGH and a little bit slower from LOW to MID?
It’s hard to adjust low/mid output correctly and over mid it looks like raming is not moving, until i see double blink as max value.
S21B CULPM1 at 9A? Let’s do this.
what led is?
Rgwn’s GT-FC40
More flashlights with USB-C , that’s great !
My previous order is still on its way, but I’m really considering this M3-C , and grey S21B. This forum has made me buying too many flashlights lately :smiley: :smiley:
I really hope M3-C will be available in grey body color :slight_smile:
Hey, stop holding out on me. Give full details! This is a 6V driver presumably and 12V LED. Also, did you need to make changes to the gasket?
Sorry my man, busy af. Driver is Convoy XHP35, emitter is Rgwn’s GT-FC40 which is 7070 12V footprint but R9080 and rated to 40W (yes, still no proper 3-4ABoost drivers :(...).
Since it’s 7070, stock gasket and reflector is simply perfect fit. So you just need to install Simon’s 12V driver which is the same size as stock M21C driver and swap emitters.
That’s it. The most beautifull build so far. This emitter is simply amazing
Left-GT/FC40 ~4500K 90+CRI, OP reflector
Right-Stock XHP70.2 5000K, SMO reflector
Wow, that is one amazing shot, it says it all !
Any link to a datasheet of the LED?
This is amazing. I think this gotta be the next BLF groupbuy
+1.
I would like also Convoy do a small host zoom AA / 14500 or even better AAA zoom keychain.
Because all I have are cheap press fit components with suck Drivers/Led
It looks beautiful and impressive. Definitely an interesting alternative to XHP70. What happened with the amount of lumens and the heating of the flashlight?
I don’t have any meassuring equipment but to my eyes it shoots lumens like stock xhp70.2 and it’s with OP reflector. Go and check Rgwn’s WTS thread for details.
For me it’s one of the most impressive emitters yet. Datasheet shows it’s Nichia219B like but 10X more output. R9 is 80, only 219B and E21 emitters have those specs (well not only them but those we know).
It can hit 3000-4000lumens with good driver
