Looking for EDC single emitter 4k anduril?
Sofirn SC31 pro 5000K
jon_slider - thanks for that link btw. Looks good and I didn’t know about it. Mmm… Might have to acquire.
Fantastic,there are other models side/rear click with simple Smooth ramping UI and sublumen with 18650 extension tube that you know?
The Jetbeam RRT01 2020 version which has 2 extension tubes to be used with 18500 and 18650 cells. You won’t probably find a smoothest ramping than on that rotary magnetic ring flashlight!
Oh yes, look very interest but I search side/rear click,also native support 18350/18650 would be better
KR1 with XPL HI 5D
+11 though no 4kK option
the light MascaratumB just told you about does all those things, native 18350, and with extensions also uses 18650, and it does have a tailswitch.
Nothing out there, sc31 pro close (i own one already) but the 4k temp is top of the list as all of my lights are 5k+
I’m leaning toward the sofirn if25a 4k for 30$ next while i wait for something slender 4k anduril. sp10s hopefully will run sst20 4k
Sp10s is not an anduril light
Consider getting whatever host you prefer, and having the LED changed…
none of the lights I use have the original LED the host came with:
Yes i meant once its finally released (other thread on here)
I didn’t want to get into led swapping as i already have so many hobby related gear that sits around.
Maybe a convoy s2 would hold me over, is there a high cri =<4k with ui shortcuts to moon and high?
Any other brands would be ok 30$ or less
You can’t really have shortcuts on a mech switch light. You can set it to turn on in moon and switch to high in 2/3 taps of the switch with several of the mode group options however.
Hi Jp9mm. If you’d consider an angle light, The Astrolux HL01 is a single emitter with Anduril. A little on the heavy side though.
Yes sure nice light thanks.But I don’t mean rotary control,just by switch
You could contact Hank at intl-outdoor.com and ask if he can sell you a D4 with a single XP-L HI 5D emitter, as per the KR1.
if you cannot get everything in one light what will you choose?:slight_smile:
EX11.2 ?
or
2020 RRT-01 ?
or
FW1a ?
Why only a single emitter?
Hank can sell you a Noctigon KR1 with SST-20 4000K FA3 if you email him and ask.
High CRI, great tint, and decent throw. I have one and I like it a lot.
Optic compartment is sized for a quad optic. I think they’re something like 8mm tall. The optic compartment too short to use an emitter properly sized for a single-emitter.
And there’s no point in using the quad star with quad optic and just one emitter installed. Sure it would work, but it would be inferior in every way to a D4 with all 4 emitters installed.
If your goal is a single-18650 light with sideswitch, single-emitter and Anduril, your best bet is to probably obtain a side-switch light of your choice and mod or replace the driver.
+12
Currently only 5kK SST40.
I heard that Sofirn also has plan to release 4kK (SST40) version , not clear though when that will actually be available.
is there any other flashlight with SST40 4000K ?
You are probably thinking of/they meant to say SST- 20 4000K. AFAIK no SST-40 bins that are below 5000K exist.
