I am in exactly the same position. I suggested to Manker an alternative carrier that I know ships flashlights with batteries to South Africa for Banggood.
Having emailed them with these details 5 days ago I haven’t had any reply form Manker either. Hopefully this is not a bad sign and they will look into alternative carriers.
The new Manker UI seems to be pretty good from my experience with my E02 II. The multiple moonlight levels are its own little sub routine, if you need low light levels, several to choose from. 180 lumens on low sounds like a lot for a low, I agree, but like you, I decided with the multiple moon levels to give this combo a shot with the E14 III. Vinh’s video on the UI was also helpful. To be honest, even the old Manker UI everyone disliked was good, except for the “hold for off” part no one seems to like. The old UI let you customize each level like the new one does for moonlight level.
It looks like Manker is using bulk shipping, e.g. they send the lights in bulk to your country, then their courier splits it and ships your order individually.
Mine is USPS and hasn’t been received either, but don’t worry. This is pretty standard.
Does anyone know how the tritium works for the e14/mc13? Wanted to add a red vial to the back of each but don’t know where to start/parts to source. Any help is appreciated!
Also, was green the only glow gasket that was provided? Really hoped for a red one but the green is awesome nonetheless.
Tritium you can buy from mixglo and then I’d recommend their UV glue they sell with it that way the glue dries clear and won’t yellow in the sun. I believe the tritium for the back is 1.5mmx6mm
