I’m not sure if that applies on Amazon? In any case, I don’t have any codes. But for what it’s worth, the price on Sofirn Official was $9-$10 iirc. Only $2 more and you get it in less than a week.
Actually, there is no true 670nm chromaticity bin of Luminus's SST20-DR. The good news is that Sofirn told me they were able to get some with a standard wavelength of 660nm peaking up to 670nm. That should be something in that yellow highlighted bins.
First of all, I do not expect any huge differences between those LEDs. They will probably be barely visible. I suppose you may notice a slightly better beam pattern and a bit more brightness on high mode. XP-E2 photo red has a smaller die area than SST20-DR, so the hotspot of the new version should look a bit wider.
I hope to receiving some news from Barry after the national holiday.
Barry was so kind to send me a quick whitewall-shot from his smartphone camera.
From left to right...
Sofirn C01 5mm 670nm (prototype)
Sofirn C01R SST20-DR 660nm (prototype)
Sofirn C01R XP-E2 PR 660nm (series version)
Comments based upon some feedback from Barry:
actual perception of deep red color is more intense than indicated here
C01R SST20-DR is quite similar in maximum brightness - although actual brightness may differ but needs to be measured using a lux meter
hotspot beam shape/profile of C01R SST20-DR is yet to be reviewed in detail as any artifacts cannot be assessed on that picture - for now it looks quite similar to XP-E2 PR
production of C01 using the 670nm 5mm emitter may be revoked as the beam shows significant distortions - final decision is not made yet
Not uncommon for 5mm LEDs. Maybe much less dramatic in real world situations? If Sofirn has some stock and decides not to sell the C01 w/ red LED, they need to put the LEDs up in their shop :innocent: .
Agreed. I do expect a less distorted beam shape when used in real-world-scenarios. However, these AAA keychain lights are meant for close-distance lighting, so something between 10cm and 3m max.. I guess with such a distorted hotspot Sofirn simply fears too many complaints of customers. Not sure though how many of this LED were sourced, probably just a bunch for testing.
I would love to take some proper beamshots of this light in actual real-world-scenarios but it's up to them to decide if they pursue developing this version or not. I did not get any information about the new C01 lights yet but the odds look good they will start with manufacturing in October 2020, too.
So I think the far right beamshot is the current run, there’s a few left online it seems at least at Amazon. The middle is the next production version, which looks pretty similar to the present version, and what’s the one on the left? Was there thoughts of making two options going forward, or more likely a single version between those two? Pros/Cons of the three?
See my post #828, left is a C01 prototype using a maxed-out 5mm LED with 670nm.
Regarding C01 using a low-yield 670nm 5mm LED I can only guess but I presume that Sofirn got also thrilled about the medical effects of deep red light to recover/revive color perception. There is a separate thread here that deals with these effects, discovered and invesigated by UCL, UK.
As the original driver of C01 barely made 1 (one) lumen with that LED, they tried some new driver pushing this LED to more brightness. It could probably be somewhere around 2-3lm with high intensity whereas the other C01R lights were operated on low mode (approx. 0.5lm). However, with only one mode available this brightness is way too high for treating one‘s eyes with deep red light. Should Sofirn manage to improve the beam pattern, I would recommend using a firefly and a high mode here. Moreover, I want to underline that shining light into one’s eyes can be harmful, regardless of its luminous flux or intensity.
