Maggie the Mag or Maggie May as I like to call her. Helping a well used Mag back to life. Photo Heavy - It's Done!
The baking soda probably helped as a mild abrasive. Once the potassium hydroxide touched the aluminum tube of the flashlight, it would have reacted immediately and no longer due to the following reaction:
2Al(solid) + 6H2O + 2KOH —-> 2K[Al(OH)4] + 3H2 (gas)
Greased Lightning worked to remove the anodizing because it contains sodium hydroxide, another strong base. Many types of oven cleaners and drain cleaners would work also, as they generally contain sodium hydroxide or other highly basic chemical.
So what can be used to “contain” Potassium hydroxide? Will it eat thru epoxy? How about plastic? Most plastic containers are chemical resistant. I use them for stripping the ano and I haven’t seen any reaction with the greased lightning.
Wow. Talk about resurrecting the dead. Good luck with this. I know you do great work and I look forward to seeing what you end up with.
Looking good, Justin!
Updated with more photos on the progress.
I went ahead and made a Dummy battery for this light. I figure if someone uses Alkalines, four of them would give an initial 6v and that's not really a good thing.
d1
d2
Not great, but it will work if needed.
Have you made a decision about the emitter yet?
Yes,
I couldn't find all that much and didn't find what I wanted. Craig at IS had some T5 leds on 14mm stars and I was going to put one on a short pedestal, so the beam could be adjusted, by turning the head in and out. Unfortunately he's out of stock. I ended up getting a T5 on a 20mm star, so it will not be a focusing beam, but a pre-focused beam. Not what I wanted, but what I got. The driver is coming from E1320. 1.7A. I'm not going for mega bright, just a light more similar to a stock maglite. Well, it will be brighter, but you know what I mean?...
So no hotwire..^^
Actually 1.7A is great for runtime and brightness. If I had any patience, I'd mod my bigger Maglites, too. But I'll stick with the 2AA Minimags.
How much is a 4D Maglite in the US? I have one I dont really need..
20 dollars.
Not great? That’s fantastic!
Old Lumens, your a hard task master. Plus 1 with JohnnyMac.
Updated in post #1
07-13-12
Really, I have just learned how to angle something, so when I take a shot of it, it comes out loking good, without showing how far off center it is. The center wire is off quite a bit. (I didn’t use my drill press), old habits die hard and I drilled it by hand. It’s way off center, but at the right angles, it does not look that way. :wink:
Old-Lumens: “Really, I have just learned how to angle something, so when I take a shot of it, it comes out loking good, without showing how far off center it is. The center wire is off quite a bit. (I didn’t use my drill press), old habits die hard and I drilled it by hand. It’s way off center, but at the right angles, it does not look that way.” Gotta admire honesty!
I'm laughing. Honesty? Why would he tell us its crooked and then take pictures that show that it is all true? Funny buggers. I still love your work. I have fitter and turners at work that using a lathe you put them to shame with your basic tools. Good stuff.
Because I did? or because I can.Wink
f1
The back end is really out, you can see it easily.
f2
The front is less obvious, but still off center to the right (actually more towards 2 o'clock). Yes, I expect perfection, but I've never found it in all these years, so I continue to try and when it's close I grudgingly accept it, but when it's not, I reject it.
To me, this is a throw away, even though I'm not going to throw it away.Tongue Out
The light is done now.
Most plastic will be fine. Some epoxy will resist degradation by KOH, some won’t hold up so well.
Cole Parmer has a decent chemical compatibility database. Select “All” from the material list and “Potassium Hydroxide (Caustic Potash)” from the chemical list.
Excellent work, Justin!!
