Thank you…
I haven’t read this yet, but thanks In advance. I was hoping someone would review this!
On to the reading…
thanks on the PWM…high PWM is acceptable…it looks a lot brighter than the eagletac…looks like it`s on medium…
Both lights were not on high, the Small Sun was on low and the Eagletac was on the second from the lowest setting, the cameraphone tends to exaggerate the contrast, but both beams were about the same brightness but the more concentrated spot tends to look brighter, on high the eagletac is brighter (For now!)
ahhhh makes sense…
Took some pictures outside, the phone’s camera is not very good so you might not notice much difference, someone has to tell me how to do the mouse over thing to compare pics!!! Please!
Distance to the fence 140ft.
Eagletac M3C4 XM-L on Max
Small Sun ZT-T13
Thank you for info and beamshots
doing a mouseover…
-open up the “reply” tab…
-click advanced editor
-put your mouse off image in the url
-click advanced and check the box use alternative image
-put that same url in the “mouse off” box
-put the mouse on link in the “mouse over” box…
save and RELOAD before you give up…I always have to reload before it works…
Thanks Pounder! I will give it a try!
Mouse over attempt #1 Mouse in Small Sun, Mouse out Eagletac, Let me know if it works ok?
works great!
Another thing, The rubber grip comes in two parts a ring and the combat piece, I think that the rubber combat grip and ring needs to be stiffer, this one seems soft compared to surefire’s combat grip, in an emergency if you grip it too hard you might pull it off the flashlight, maybe one of surefire’s rubber grips might fit this light.
Mouse Overworks fine !!!
Thanks for checking!
Will keep that in mind for combat after mine comes. :bigsmile:
I have so many big head 2x18650 throwers now that I need to buy some more diffusion film…
Possibly solarforce l2t would be better/easier to get I talked to a surefire rep a few months back and they said I couldn't buy a replacement ring for my c3.@alex the star seems to be the 30mm one used on the trustfire x9,if you can verify that I would appreciate it.
Measured with a ruler to 24mm, thanks for the info about the solarforce, I already tried ebay for the grip only found this, not sure if it fits at all or maybe they are something completely different
You can you also measure the reflector and the outside diameter of threads around the LED.
Thanks alex,my local gun shop sells surefire gear and I tried those on my light and bottom line is they stink.Surefire has discontinued all sorts of stuff and I even asked to buy a m3lt cigar grip and they outright said no.
Sorry zizo, I’m not opening that reflector again! The silicon seal was a major pain in the butt to put on right, the best I can measure is 52 mm inside the parabola (To the edge or reflecting surface) and maybe 54-55mm outside diameter, I only opened it up because it had lint and wanted a clean reflector, if it came clean I would not have messed with it in the first place.
There is some wiggle between the threads of the reflector and the heatsink while being tightened so I had to close it very slowly and carefully to make sure that the led was perfectly centered in the reflector since I am not using the centering ring anymore, it has better throw without it, IMHO.
Look at that perfectly centered led, I like it!
