Need to add registered mail as well, $2. Aliexpress is almost 99% registered, coz escrow sort of requires that (else you raise a case and they are screwed). It’s all factored into the overall costs of coz, but as you can see sometimes you do get gems.
BTW, does this work? 10000 grit. I am not anal or want to get a polished surface….just finish with 10k and that’s it. The Taidea 8000 grit is too expensive! (maybe it’d be faster, but i am not finishing a lot of knives)
The Leen looks really good but it’s a little short for my hand. I wonder if it’s really 440C?
Is the best price people have found at Aliexpress for $13.50. It appears that as a new company, the two versions of this knife are all that they have so far.
And there is only 3 different Inron knives in aliexpress shops.
For Leen there is 2 different knives (quite similar): 1201 and 1203. One model with G10 or steel handle: respectively 1203-1 and 1203-2 .
I strongly believe that the greatest item to sharp a razor is a leather strop with diamond paste. If you want to save money and buy a very fine grit sharpener, you can use rectified glass.
I wasn’t sure about that, when I ordered from those two stores I noticed similarities in family (second) name of the sellers and also in their email address.
But the fact that it is an other aliexpress shop still be true.
Yes it is nice and very effective, the “power to sharpen” of diamond is above all other “commonly” used products. Diamond is your best friend. :bigsmile:
I use leather strop and leather strop with diamond paste for my straight razors.
This is great but preferably to refresh and / or maintain the sharpness of the edge. To rebuilt a bevel edge, I prefer a (water) stone. It is also easier to keep a constant angle.
For a flat bevel, a stone is better (but it depends a bit on your skill to keep a constant angle). Or use a leather strop (+ diamond paste) glued on a piece of flat wood. As the leather (if thick) surface is less rigid than stone, the bevel (= profil) of the edge should be slightly convex. For a flatter bevel, thinner leather is better.
Now we need a “sharpening tools and techniques” thread.
Bro thanks…. i am new in this knife thingy. But i think 12k should be fine for me and i’ll check that out later. That’s 1 micron, versus the 0.25 for the finest diamond paste.
Not after the best mirror-finished edge like what we can see on other forums, that’s really too much work and besides it’d dull down.
